Home > Help Needed / General Tech Chat > help identifying rockers
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Im stuck! i have three sets of rockers here...
One is from my old 998 engine,
One is from my old 1275 MG engine,
One is from a 998 engine that i took it off tonite (to compare)
They all look exactly the same!!!
I need to find out which one to put on my engine (1040cc 1litre block with turbo 1.3 head)
is there any difference i can look for??
they look slightly different spacing to me. there is a difference to 998 and 1275 spacing. as long as you get the set that match the valves then it will be fine. they;re all the same lift etc.
jamesfawcett
Member #: 218
I think its just the photo i held them together and they all match up *surprised*
Tomorow whne its light again ill go measure them in mm
SumpNut
Member #: 28
mm dont be daft - measure them in yards!
No difference what so ever
Dangerous
Member #: 417
Pretty sure they are all the same,It's only the roller tip ones you have to play with the spacing,as the roller is only on 2/3rd's the width of the tip.so you change them round for 1275 or 998 inlet to exhaust valve gap.
andeh
Member #: 97
Near Daventry, midlands
they are indeed all identicle, however check for wear, slack in the rocker on the shaft and rebuild if necessary. New shafts and selected rockers from a few old sets will see a vitrually brand new set for only £10 (new shaft cost).
Edited by andeh on 12th May, 2006.
jamesfawcett
Member #: 218
nice one ok i will pick the best of the three and check the condition of it! thankyou
also, can i just ask whats the little rectangle shaped thing on top of one of the oval metal pieces that turns round? What does it do?
The bit you mention is a grub screw, it locates into the rocker shaft to stop it from rotating or moving axially.
If I were you spend 10 mins and take a set completely to pieces, you'll learn far more about how the work and how they fit together doing that than we can teach you on here. After all, you have got 3 sets to go at.
evolotion
Member #: 83
Glasgow, Scotland
theres no difference between them, i remember posting jsu that on miniclassic years ago whwen i noticed there was no difference and i remember a few regulars dissagreeing. the only difference(if you can call it that) is that the wear on teh rocker tip's will be different from 1275 to 998 due to valve positioning.
Denis O'Brien.
