Home > General Chat > OT- Windows Explorer - folder propeties options?
Is it possible to set up explorer such that you can view the size of folders without having to right-click and select propeties?
Reason I'm askign is someone is taking up gigs, and gigs of space in our departmental drive, but no-one is admitting to it. IT services are their usual helpful self to assist - I suspect because it's not disrupting them ebaying or downloading music...
Any tips/clues?
Mike
Member #: 107
Sunny Sussex
ta-daaaa..
http://foldersize.sourceforge.net/
wahayyyyyy!
That'll do for me!
Virtual pint on it's way Mike. Cheers!
ok - here's another one....
is there any way - aside from 'printscreen' many times over - of printing off this HUGE list of folders or saving as a bitmap/jpeg/whatever???
Mike
Member #: 107
Sunny Sussex
yup, (presuming using XP)
Start/Run
type cmd
browse to the directory in question (i.e. cd c:pictures) (insert a backslash after the colon as it wont show here)
now just type "dir > list.txt" (without quotes)
now just browse to the same directory with windows explorer and you'll have a file called list.txt :)
if you just want jpegs listed, type "dir *.jpg > list.txt" instead :)
Edited by Mike on 15th May, 2006.
Not using XP; it's 2000 I think...
still the same in 2000 dave
Mike
Member #: 107
Sunny Sussex
y same, except in the Start/Run comand box you may have to type command not cmd
I thought cmd worked on 2000 too, could be wrong though
Mike
Member #: 107
Sunny Sussex
cant remember either tbh been a while since i used it!
Cheers guys.
CMD does work in 2000 btw- I'm always using it to get my IP address...
geeks
*wink*
