Home > General Chat > OT - Any plumbers here??
Mike
Member #: 107
Sunny Sussex
my combi tonight has started making a horrid high pitched whislting whenever a hot tap is turned on, but not when the heating comes on, any clues?
Dangerous
Member #: 417
Diverter valve..little moter(egg shaped) that shuts the radiaters of to give heating prefferance to the hot water when a tap is run
Mike
Member #: 107
Sunny Sussex
hm, cant see anything like that under the boiler in the pipework, would it be IN the boiler?
Dangerous
Member #: 417
Mines next to the pump,one pipe comes out the boiler,one goes to tank,one goes to the radiaters.says honeywell on it and has a little lever on the back so you can latch it on to heating water
paul25
Member #: 596
You'll need to remove the cover. If your boiler has a "summer" setting, activate that and you should hear the diverter valve moving clockwork whirring.
