Home > Help Needed / General Tech Chat > slave cylinder
clubby_turbo
Member #: 403
sydney Australia
just a quick one, whats the difference between a verto clutch slave cylinder and a pre-verto clutch slave cylinder and which ones better??
Cheer's. Chris
998 turbo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
apperently yes...
But I'm fairly sure I've mixed them up in the past and not had a problem.
AlexF
Turbo Shed
Member #: 30
Epsom, Surrey
i think the verto slave cylinder has a circlip in the end to stop the piston pushing out, where as the non verto has the two big nuts to stop over travel of the clutch arm so does not need the circlip.
i thought i was told that the verto had an internal spring that pre loads the clutch and should not be used on a non verto set up
on the other hand i think i have one one my car and it works, so who knows.
Ben H
Member #: 184
Melton Mowbray, Pie Country
The Verto slave is shorter. They are kind of interchangable, but you are better getting the correct one.
I don't think there is a better or worse, just the correct one for the correct cluch.
http://www.twin-turbo.co.uk
The non verto cylinder definately has the spring and circlip fitted. The circlip is to stop you being able to push the piston out of the bore hence losing fluid and damaging the seal. The spring is fitted with a nylon cup that retains the seal in the correct place and keeps it square to the piston.
clubby_turbo
Member #: 403
sydney Australia
alrighty, thanks for that!
chris
998 turbo
