Home > Help Needed / General Tech Chat > Smoking only just bulit
mikemph
Member #: 449
Oxford
I have just built turbo engine, when I first run it no smoke.
I have now been round the block a few times, now seems to have started smoking, seems like its rings have the plugs are well coated with oil.
Ideas welcome!!!
Let the rings bed into the bores.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
what oil are you running?
what was involved in the rebuild?
AlexF
mikemph
Member #: 449
Oxford
new pistons and rings from morspeed, block bored and honed, oil jets, mains strap, new bearings, etc you get the picture basically new engine.
I thought it might be rings bedding but never seen a newly built engine smoke this much but I will see after giving a bit more of a run.
The oil is some cheap 10/40
Kean
Member #: 341
aka T2clubby
South Staffs
What about the head?
Have the guides/seals been done
mikemph
Member #: 449
Oxford
Yep head has new bronze guides from avonbar and new stem seals.
