Home > Wanted > few little bits i need for fiishing
pot_dan
Member #: 326
bradford, west yorks
will be having a look round the 'mini specialists' today to see what i can get but if you ca help and i fail when out, hears the list:)
the taperd washer type things that go inbetween the flange and hub nut.
front hi-los copies or genuine, not botherd.
era caliper bolts (i think i will end up going to minispares for these but if anyone has any that would be great)
switches..
i really only need these if they have the conectors on the back with an inch or so of wire with them..
heated rear screen and rear fog light.
2 chrome bumpers but must be in very good condition.
a shiny rockers cover - WHY?
i will have no doupt forgotten something but wll be back to update:)
thanks! Dan
http://turbominis.co.uk/car/105/
Tapered washers I may have these somewhere will have a look
ERA caliper bolts try Somerford Minis, not sure if Minispares stock them
You can also get the connectors to fit the standard switches from Merlin Motorsport, they are not very expensive.
minit3
Member #: 602
dan my mini came with a pair of chrome bumpers give me a ring as im going to use painted ones if im right i think there in ex cond
pot_dan
Member #: 326
thanks for checking tom, i sorted the washers out, but had a uge problem trying to get some bleed nipples for metro 4 pots! think should be sorted now tho:)
i know i was thinking of something else i need and now i cant remember what it is :(
thanks, Dan
