Home > Wanted > 3 way red breather pipe splitter thing
jamesfawcett
Member #: 218
Bingley, West Yorkshire
when taking the hoses off today, the red 3 way splitter thats between the bottom of the air box and the breathers seperated into two! There were tiny metal circle grills inside that fell out so i think it has had it now? Just wondering what these are called so i can order a new one? Unless somone has one i can buy off them?
1380Turboman
Member #: 221
I should have 1 feeble....not sure if i am going to need it yet.....might try and suss out some small k&n type filters for the breathers instead.
Will let u know asap.
Paul.
Pretty sure ive got one kicking about and i wont be using it, using a catch tank instead.
Ill look it out and get back to you. ?5 including the post if thats ok? (and its ok too!) paypal is easiest. Unless you have an oil feed pipe to swap for it?
jamesfawcett
Member #: 218
ARGH! ive just paid 10 pounds for one this morning! if id waited another hour or so i would have read those! Managed to clean it up - this one was full of mayonaise where the head gasket had gone i presume!
