Home > 998cc > 998cc mega top pistons
martpaul
Member #: 668
newton aycliffe (near durham)
hi all,
ive been looking out for these for a while now, and jst thought id let you all know theres been an update!
They reckon the +60 thou will be ready for july06!
heres the link to them!
http://www.minispares.com/Product.aspx?pid=38611
morspeed are saying i need a 3cc dish to get the right cr, do you think i can have these flat tops dished to that?
thanks martin
As thay are a brand new piston (you may even be the first to own a set) it's impossible to say. But Mega pistons are well made and should therefore be thick enough to allow for the removal of sme material.
3cc isn't much either. But it really will be suck it and see.
wil
martpaul
Member #: 668
cheers, just out of curosity what cr am i looking for? i want to keep some poke at low revs if you know what i mean as its going to be used on the roads as well as track!
thanks martin
Good question.
all I can say is that I run mine at 8.3:1 and I get boost around 4k with a T2 and T3
martpaul
Member #: 668
yeah thats a good point!on the head side!
well they said they recommend 8.25.1cr n to gain that i need 3cc dished pistons!
im using a 12g295 head (he didnt mention what the chamber size was,i forgot to ask), 4x4cosworth intercooler, i dont really have a power target, its more on the reliable side im after!
do you think its possible to gain pluss 100 and still be reliable?
cam choice is a n/a mg cam,
oh and yeah optimax, as its the closest station!!!
oh thanks by the way!!!
martin
To get that CR with flat tops you're going to need chambers around 33cc (assuming +60 bore).
I don't know how big thw 295 cjhambers will go, but I suspect that this is why Simon is suggesting a 3cc piston dish.
You know too much Pete.
Ben H
Member #: 184
Melton Mowbray, Pie Country
We may beat you to that pete, with any luck it will be on the rollers next week with the T3. The results of that should tell us where to go.
http://www.twin-turbo.co.uk
martpaul
Member #: 668
If there boost isnt kicking in til 4k, isnt that because there using a t3, will that be alot lower or just alittle lower with the t2 i plan to use?
when would you expect the power of the t2 to come in?
i cant wait for the mag it will be a great help and read!!!!!
thanks martin
andeh
Member #: 97
Near Daventry, midlands
I think their T2 kicked in at the same point that the T3 kicked in, around 4K. Its detailed in one of the posts above.
Looking forward to see the results Wil and Ben, good luck.
martpaul
Member #: 668
mind the way i drove it when it had the standard 998cc in, was always at the top!only cause it was so flat! :)
