Home > Help Needed / General Tech Chat > Carb Spring
RED850
Member #: 89
Sydney Australia
Hi all,
my engine has a slight stammer/splutter on light to moderate accell from about 2200o 2500, i am yet to double check the oil but i believe it to be ok, so i thought maybe the spring is a little week, i am running a std spring with a few engine mods and a BAH needle, good cam etc etc.
any thoughts?????
thanks Grant
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
Kean
Member #: 341
aka T2clubby
South Staffs
What boost are you running?
In my NA minis I tend to use a thinner oul than I do in the Turbo, so might be worth trying something thicker like gearbox oil.
RED850
Member #: 89
Sydney Australia
I will be running up to 15psi, but normally about 10 to 12
14.0et @101 mph
T3Tone
Member #: 252
Sunny suffolk
Going from 20/50 oil to 90W gearbox oil made mine alot smoother, i would certainly give this a go as already suggested. I still use the standard spring so maybe the stronger one avonbar sells would improve it more as its not quite 100% hesitant free when coming on boost.
-MINI CLUBMAN 1380 TURBO-
just a thought grant but......
have you tried the T price trick?????
if not
do a search and get up to speed with it
a fine write up by turbo dave.
RED850
Member #: 89
Sydney Australia
i dont think it will help at all cause the mixtures and everything else is fine and the carb is in good nic,
ill try the oil in the pot and see how i go
thanks to all
14.0et @101 mph
