Home > Help Needed / General Tech Chat > Freezing Manifold
Staggy
Member #: 947
New Zealand
Well got a bit of the old carb ice going since the days over here are hoving around zero. The manfiold sticks out in the airflow. I was thinking of some sort of 12v heater to keep it from icing up. Anybody have any smart ideas?
Caution !!!! Slippery when boosting
Some OE stuff uses a heater in the manifold to stop this happening, early VW Polo's for one, may be worth some investigation?
Staggy
Member #: 947
New Zealand
tom could you explain some more how the polo one works?
It is an electric powered heater, it sits in the manifold in the airflow, it has a series of "pins" that stick up into the airflow to give more surface area.
Otherwise maybe you could attach a pipe to the inlet manifold and run hot coolant through it to stop the carb icing?
