| Home > 998cc > 998 project engine | |||||||
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
10th Jun, 2006 at 08:58:43am
The plan so far is to use parts from several low mileage 998 engines which i've collected, selecting the best parts. I'll try and use some of the earlier full skirt pistons, as i seem to remember wil and ben saying that they've had more sucsess with these over the later slipper type?
Edited by andeh on 10th Jun, 2006. I've seen the future and tbh its Pie
10th Jun, 2006 at 09:02:17am
I'd personally spend the money on the 295 head. If you use a 940 head you will need to get the block pocketed, which if it is a throw away project engine will be a waste of money when you bin the block, whereas the head can be unbolted and used again.
10th Jun, 2006 at 10:14:47am
Thats a good point tom, cheers.
10th Jun, 2006 at 01:49:14pm
I have been reading up a bit on squish to try and get a better understanding of it. From what I have read (and this is not forum reading) I get the impression that for out and out power squish can be more or less ignored. Yes it helps more fuel get burnt more efficiently, but if you are happy to have high unburnt hydrocarbon reading then you are better spending money in other places than trying to improve squish.
http://www.twin-turbo.co.uk
10th Jun, 2006 at 03:26:07pm
having no mot here on the island, thats an interesting take on squish vs. high hydrocarbons.
10th Jun, 2006 at 04:30:59pm
Actually Joe, that is what I am doing. I have a 1030 at the moment with flat tops and a 940 head and 276 cam. I intend to just put another 940 head on with slightly opened out chambers and a T2 and see how it goes. Probably run about 9:1. The 276 cam may get changes to an MG.
10th Jun, 2006 at 09:04:07pm
I've decided on the following spec for my 998:
12th Jun, 2006 at 09:06:27am
Peter, I agree that squish is important and ultimately will make more power. But in the reality of the engines were are making, and I know you are trying to push the limits of the A series much more than me, it seems trying to engineer in squish is way above most peoples knowledge. I f I was designing an engine from scratch then yes squish is vey important, but when modifying an A series I don't see it as vital. Like you say there have been good power results from engines that should have low squish so for most of us mortals it can generally be ignored. Perhaps this a a bit of a defeatist opinion, but modifying a 60 year old engine is always going to be a compromise.
12th Jun, 2006 at 12:51:42pm
I smell a red herring!
5th Jul, 2006 at 07:09:51pm
I've decided on spec, i'll stick a de-bossed MG head on with chambers to suit. Cam will be morspeed ph2 for now, but i'll also give a 1275A+ cam and maybe an MG cam a go at some point.
28th Feb, 2007 at 11:13:32pm
Andeh,
1st Mar, 2007 at 02:25:28am
I've only collected parts thus far as i have been busy moving house/setting up a new workshop. Needless to say this engine will be built this summer along with the supercharged version and my short stroker.
The aim is to run 12-14psi using a bleed valve. I'll make up an adapter for the std exhaust manifold to take the GT15 as i dont have enough wedge to do anything fancy. I'll be using MS for ignition.
