Home > Help Needed / General Tech Chat > boost guage
nobbie
Member #: 162
i also would like to know where to conect the boost guage to please.
does it conect in between the pipe going from the end of the dump valve to the inlet manifold.
You could connect it into the dump valve pipe which goes to the manifold, i used to have mine like this and it seemed to be fine. Or you could tap a new connection into the manifold and connect it to that.
Phil. *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
new connection is the best way :)
alex
AlexF
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
depend which boost you want to now, the one at the comp side to plot a map, the one at the engine side to know he engine boost/vs cr.. or just to have a boost gauge....
I 'm using boost gause only to set the boost pressure and then don't use it any more; so I'm reading the pressure at the comp side on the fuell line, on the plenum and at the manifold,when all the numbers are known and ok i'm not using it any more.
fab
