Home > General Chat > Hello - N/ hemisphere Bimmer Twinki - yesterday!
johnK
Member #: 690
Norfolk
Hello all - been a member a while now and know a few faces on here but never posted - thought you'd be interested to have a ganders at my K headed twinki - was very pleased to see madmatt's going in spectacular fashion on the garage floor - spurred me on to finish it off. If the link doesn't work pls excuse me as pc skills aren't my strong point. The vid clip is of the first 30 mins running yesterday, running cams in etc, base map isn't too bad but its on the rollers at the end of this month - following what madmatt was saying the sound/feel of the engine is very strange and also very smooth - the engine is solid mounted but doesn't rattle and roll like the 5 port did - strange!
brief spec:-
1380cc - Omegas 4 bolt main, innocenti rods,med crank, paddle clutch, s/c box/drops, fully ported K head (very interesting flow figures-you turbo boys will like it!)custom cams, my design exhaust manifold, EFI management, traction control/launch control - circa 510kg
http://media.putfile.com/Johnk-16v-K-Mini
cheers
If Carling made Mini engines
johnK
Member #: 690
Norfolk
thanks Peter - its been a long slog for 5 months solid- but it looks worth it - looking forward to getting it on the road and seeing what it feels like - will be nice to see more of the little engines in the future as well.
cheers
That looks great! - sounds meaty too!
good work!
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
nice install dude, sounds sweet *wink*
16V project underway
John Kimmins... Why does your name sound familiar? *oh well*
That aside - well done on the install.
Will it be at Avon Park in July?
Edited by turbodave16v on 12th Jun, 2006.
Turbo Tim
Member #: 177
Woburn Sands
Looks like Simon has another one running
johnK
Member #: 690
Norfolk
Hi Turbodave - a regular at Avon park in class C , we've probably not tripped over each other formally!!
Turbo Tim - Simon prepped the block and modded the oil way in the K head - the conversion plates/ adapters were based on his early designs and made through my company - the rest is my blood sweat but no tears!
cheers
Nick
Member #: 154
Midlands
glad you've got it up and running now dude. looking forward to seeing it at avon park!
Sweet
giallofly
Member #: 164
The Stig..
Newport Pagnell
John, we've met......
antman
Member #: 358
Snetterton, Norfolk
John, Well done on getting it running. I seem to remember that mini in one of the mags and that you live in the norfolk area?? If so, i would be very grateful for a look as mine is nearing completion.
johnK
Member #: 690
Norfolk
Hi Jon F - congrats on the metro racing - very nice work- next time your at Snetterton I'll pop along, Antman - I am indeed based in the middle of Norfolk around Norwich area - not a problem for you to have a look.
JK
JohnK, Well done mate, sounds and looks great, does the bonnet clear the head without any mods?
I'm interested to know more about your cams, who did you get to grind them for you???
johnK
Member #: 690
Norfolk
Jimster - the f/glass bonnet I have "just" touches in one point literally - which is a bit of a pain as it would be nice to keep std profile - ah well can't have it all and it certainly doesn't spill out like a kad. For a turbo application you wouldn't go far wrong with the std k1100 - not RS cams - I have the lobe measurements from the std cam if you'd like them, and you can alter the overlap easily enough with a pair of verniers - they aren't any good for a high performance n/a engine though the RS cams with 284° are getting there.
- hows yours coming along?
Mine is making good progress, not running yet, but should be there for avon.
Do you know much Data on the RT, RS & LT cams, and the differences?
Which point of the head touches?? Front right corner?
Any data you have will be handy
johnK
Member #: 690
Norfolk
yes front right corner of the cam cover touches - I may "hide" the clearance under a "cooling" vent or something!
I have a very accurate cam profile (same inlet + exh)of the LT cam of a cam measuring machine - the RS I only know the timing and lift not the shapes of the opening/closing ramps - these are the only two cam profiels I know of for the UK K's, I'll get the info together and send it on.
great thanks.
danwebster
Member #: 1038
Kad setup fits under a standard bonnet if you use the standard inlet manifold. I have a special long one for more mid range torque *wink*
johnK
Member #: 690
Norfolk
Dan - you're right - I think the weber injected ones sit under the front as well? - the cam cover will always be taller than the K though!
the KAD head i have dan will prob have the bike carbs sticking up and out the front of the bonnet due to the incline so they sit something like level.
that is whenever i get around to rebuilding it ,lol.
well done on the bmw head there thought John,
carl
johnK
Member #: 690
Norfolk
Cheers Carl - don't think clearance would be a problem in the rear of your car - lots of space!!
danwebster
Member #: 1038
Its the actual vernier pulley that is the tallest part on the kad setup rather than the cam cover.
Carl - would be good to see 2 in action in one car *happy*
Edited by danwebster on 13th Jun, 2006.
"excellent stuff"! *happy*
well done
whats the expected??? HP John
johnK
Member #: 690
Norfolk
thanks Benross - as the spec looks its built pretty much full on, theres enough airflow through the head at the lift of my cams for 180 ish bananas- so we'll see what the curves look like, fingers crossed.
cheers
JK
