| Home > General Chat > WHAT'S YOUR MINIMUM BOOST SETTING??? | |||||||
31st Mar, 2004 at 06:14:04pm
Just wondered what every one else runs as a Minumum setting, or is your boost set and that's it. Best 1/4 mile 13.2 seconds @116 mph
31st Mar, 2004 at 07:36:31pm
4.5 psi :p
AlexF |
2 Posts Member #: 215 |
31st Mar, 2004 at 07:50:52pm
Never mind minimum boost whats your maximum boost. |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
31st Mar, 2004 at 07:51:08pm
10psi low bost , all depends how you feed the clutch in and what gear ratio`s u use .....
31st Mar, 2004 at 11:22:11pm
ricko, the question as about Minumum boost nothing to do with high!
1st Apr, 2004 at 05:00:44pm
my low boost is around 7 psi Team www.sheepspeed.com Racing
103 Posts Member #: 31 62horses at the wheels and counting |
1st Apr, 2004 at 06:57:14pm
Minimum boost.
1st Apr, 2004 at 07:17:47pm
So what's that - about 5PSI???
1st Apr, 2004 at 09:49:33pm
matt from the vid`s i`ve seen of yours and a coombe a couple of years ago , you need to sort your susp bushes out , but saying that once you hit high boost with the sort of torque levels you`ve got its going to be hard not break traction . Everyone knows that instructions only have to be read if the thing doesn't work....
2nd Apr, 2004 at 12:15:03am
Yes i see your meaning mate , i have now got some harder bushes in and it did help the torque steer a little. Best 1/4 mile 13.2 seconds @116 mph
![]() 323 Posts Member #: 41 Senior Member |
2nd Apr, 2004 at 10:55:14pm
mine is still set at the 4-4.5psi, just finished running the engine in, desperatly needs to go on the RR.
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
3rd Apr, 2004 at 11:21:52am
10 psi basic and 16 psi via a solenoid. Last summer the solenoid stayed on all the time. Planning to try even higher boost. |
4th Apr, 2004 at 07:43:22pm
10 is my minimum boost leval, at least double that for my maximum... On 21st Jan, 2011 fastcarl said:
4th Apr, 2004 at 10:43:21pm
looks like 10 psi seems to be a good and well used setting. for most moded Minis. Cheers people.
4th Apr, 2004 at 11:42:39pm
In my opinion, the lsd does not do much for me off the line, but it comes into it's own on the track. I still get lots of wheel spin when I pull away even on slicks. Edited by Jimster on 5th Apr, 2004. On 21st Jan, 2011 fastcarl said:
263 Posts Member #: 115 Senior Member Austria, near Vienna |
5th Apr, 2004 at 05:32:20pm
Which LSD do you use? Quaife?
Bimmer Twinky headed and turboed A-Series:
5th Apr, 2004 at 06:51:15pm
giallofly, i see what your mean, if your spinning slicks as well hell mate. Best 1/4 mile 13.2 seconds @116 mph
5th Apr, 2004 at 09:36:37pm
Sorry to be so blunt with my question matt, but I would really like to know how much boost you run to make over 200bhp. |
