| Home > Help Needed / General Tech Chat > Blocking the Filter Bypass | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
14th Jun, 2006 at 09:38:14am
I've heard a lot of people talking about blocking the oil filter bypass in the filter housing.
14th Jun, 2006 at 01:30:18pm
Well, you remove the steel bypass unit, and stick a solid plug in it's place...
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
14th Jun, 2006 at 01:33:16pm
i tried this earlier last month without sucsess, the casting is very thin around the bypass unit and doesnt take much of a tap, certainly 3/8" bspt wont fit (though that is a bit ambitious).
14th Jun, 2006 at 02:12:09pm
Well, I guess you could 'turn' a plug on a lathe that is a super-snug fit to the extent that you need to tap (not force) it in with a small hammer.
14th Jun, 2006 at 02:15:54pm
I haven't done this yet. But the method I had in mind was to leave the standard insert in place, and drill through the casting behind it, to allow you to wind a small set screw (maybe 1/4") down onto the back of the ball bearing that lifts off its seat to bypass oil, so that it could not lift off its seat, hence no bypass.
14th Jun, 2006 at 02:23:27pm
The ball and spring is contained in this 'formed' steel assembly Tom - basically, if you remove the tangs, the ball, spring and cage come out as one.
14th Jun, 2006 at 05:17:23pm
Anyway, good lateral thinking tom.
14th Jun, 2006 at 05:48:08pm
The aftermarket one is from Keith Calver, nicly cnc'd aluminium,
397 Posts Member #: 694 Senior Member Shropshire |
15th Jun, 2006 at 12:47:43pm
Also from http://mitresoftco.web123.discountasp.net/...terhousing.aspx |
15th Jun, 2006 at 01:47:06pm
ooooh I like that in black!
16th Jun, 2006 at 03:44:22pm
Hmmm, anyone seen green anodising before?
16th Jun, 2006 at 06:12:20pm
yep. green anodising is no problem i'm sure
22nd Jun, 2006 at 07:10:51pm
Had a look today.
24th Jun, 2006 at 04:45:09pm
Plan B
Edited by Dangerous on 24th Jun, 2006.
