Home > Help Needed / General Tech Chat > removing the clutch and break master cylinder
nobbie
Member #: 162
hi ya guys i am doing my turbo conversion as we speak and it is all going good, why i have the engine out of the car i am going to be removing the front subframe to give it a lick of paint, i am not quite sure on how to remove the clutch and break cylinder, can any one give me some advice please.
Easy
1) Take off all the pipes from the master cylinders
2) Remove the split pins from the pedal to cylinder locating dowells (can't think of a better name for them), then remove the dowells. All this lot is found at the top of the pedals inside the car and is a git to get at.
3) Undo the nuts holding the master cylinders in place and pull them off.
Wil
nobbie
Member #: 162
cheers mate
mini-marauder
Member #: 68
Coventry
Clevis pins *wink*
Sooperdooperturbocooperexpertengineering!
Thank you
If you are struggling - take out the drivers seat and maybe the column. If you've never done it before (and aren't a contortionist), it can be tricky to figure out how you do it....
nobbie
Member #: 162
yea i got them both off today thanks guys - no probs
