Home > Wanted > Verto clutch Thrust Sleave
The one i've got has a groove worn in the end where it has been spinning on the diaphragm because of a seized release bearing.
Any one kind enough to donate one thats in good order, that they are not using. I know a few of you dont use the verto set up and may well have one lying around.
Many Thanks
MS
i sthis that hat like thing that sits on the end?
i can have a look at the weekend if youve had no luck by then
I've got a bagfull of verto bits, bound to have what you want, but like Nic, I'm not sure what it is.
Its the top hat thing that the release bearing pushes against to depress the diaphragm/ spring
Thanks, much apreciated
I'll see what I've got when I get home, deffo got a couple, not sure of condition.
icklemini
Member #: 745
Northampton
Sure I've got a few hanging around as well...
Ta,
Dave
Thanks every one
Wil is sorting it
Big thanks to Wil_H
Thanks, Very much apreciated
MS
Hope it's ok
