Home > 998cc > would this work?
clubman_dan
Member #: 142
Winchester
i have a turbo sat in the garage, i have had it for a while.
its a kkk turbo, looks pretty small, havent got a clue what it comes from.
the blades on the exhaust side measure 45mm across (approx)
and on the inlet about 36mm (approx)
these are only rough measurments.
does this sound like it may be suited to a small bore a series?
just curious
cheers
DAN :)
I wish I knew.
Has it any tsampings that might indicate A/R values? or any number that you could google to try and finda map?
clubman_dan
Member #: 142
Winchester
i will have to have a look when i am next at my dad's as its over there at the moment, but i will put any markings up and have a search on google
cheers
DAN :)
clubman_dan
Member #: 142
Winchester
its a kkk k16, it has 50.95 cast on the inlet side.
i found a map on google, it means absolutley bugger all to me but maybe someone who actually has a clue about this can tell wether it would work!
cheers
DAN :)
From my knowledge, it looks pretty good for 12 to 15psi on a 998.
clubman_dan
Member #: 142
Winchester
cool!
cheers
DAN :)
