Home > Help Needed / General Tech Chat > Roller drop gears or normal straigth cut drop gears?
Stig
Member #: 694
Shropshire
Hi all
Just wondering what the difference is between Roller drop gears and the normal stright cut drop gears?
they are all the same except the idler gear
which there is one called a timkin roller
where the gear has been machined to accept a timkin roller, expensive around 170 pounds for this item
its supposed to be the ultimate ... it is but....
its not needed as long as you fit new needle roller bearings in the idler & gearbox case and the clearances have been set correctly
peeps on here are placing 200BHP through the needle roller bearings without any or little trouble!
suppose if you have the money though *wink*
however....
after sitting in benross's car the joy of not having the idler chattering away was most welcome
In a few years when i have money again i shall be fitting a roller jobbie
thanks nic
as you say the noise reduction is a lot better may be 80+ % better
How does the idler bearing arrangement affect noise then chaps????
Dave i have listened to many gearboxes with SC drops in
and have found that the ones with the idler timkin set up is “considerably! Quieter”
this must stem from having no needle rollers in application
with the timkin setup
the timkin idler also reduces the running clearance some what
and the timkin idler virtually eliminates the side loading on full load
mine are timkin and still bloody clatter!
Turbo Shed
Member #: 30
Epsom, Surrey
mine are Timkin and are louder than a friends normal straight cut drops.
i must be deaf then.....lol
In my experience there are different types of drop gear clatter,
the first is a loud dull slapping clatter from the idler flapping from side to side against the alloy casings (on helical setups)
the second is a more metalic sound than above caused by large clearences on the primary gear (also on helical sets)
both these types should be eliminated with SC drops as there is no side ways movement, (i've not expirienced it anyway)
This leaves the actual gear backlash noise, this does change from anufacturer to manufacturer, minispares gears allegedly have the best tolerances.
Also one thing worth noting is some people just run sealant between the engine and box this will affect the noise, (as will different thickness gaskets from cheap suppliers)
