| Home > Help Needed / General Tech Chat > Bleeding minisport 4 pots? | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
25th Jun, 2006 at 08:01:10pm
Does anyone else on here run the minisport 4 pot alloy callipers?
784 Posts Member #: 912 Post Whore North Yorkshire |
25th Jun, 2006 at 08:29:54pm
Got a set of these things on mine..!
I drill holes in everything..! |
25th Jun, 2006 at 08:59:28pm
yeah they're the right way up, and we've been using the easybleed aswell as the the old fashioned manual way (which has given us better results surprisingly)
Edited by Anton on 25th Jun, 2006. |
25th Jun, 2006 at 09:23:05pm
What else do you have in the system.
![]() 282 Posts Member #: 616 Senior Member Birmingham |
25th Jun, 2006 at 09:50:25pm
Calver also gives an interesting method for bleeding these. It should be on his website, or on the minispares forum thing.
25th Jun, 2006 at 10:37:30pm
Yes I'd also try that, I have known in the past 4 pot calipers not bleed up properly because when the pistons were fully pushed in the fluid transfer ports were blocked.
25th Jun, 2006 at 11:47:13pm
well we decided to try the gravity bleeding method earlier. opened the bleed nipple on each calliper (yes, just one bleed nipple on them!) then let them drip for about an hour while we went for pizza.
25th Jun, 2006 at 11:54:01pm
Thats still not very good is it, I know Nic had problems along these lines that I think he never got to the bottom of?
26th Jun, 2006 at 11:58:11am
I had the same problem this weekend with some KAD callipers, still not sorted it yet Team www.sheepspeed.com Racing
26th Jun, 2006 at 12:03:17pm
you could try wedging the pedal down over night and cracking off the nipples...
AlexF |
26th Jun, 2006 at 01:02:14pm
i've had problems in the past bleeding brakes but not any more. i found the best thing is to bleed as normal and when you only get a low peddle chock it down as hard as possible, leave for a few hours or over night and try them out. this always seems to work for me. |
26th Jun, 2006 at 01:24:38pm
Just a thought.
26th Jun, 2006 at 10:49:41pm
right, bit of an update on the brakes.
26th Jun, 2006 at 10:57:21pm
forgot to add that we've tried the calver bleeding method aswell with no joy :( |
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
27th Jun, 2006 at 12:30:23am
Wouldnt the calpier ballooning or moving suggest that this s caused by the pressure from the pipe, so theres a blockage some were?
27th Jun, 2006 at 12:48:47am
have yoy adjusted the rear braks?
My build thread..
27th Jun, 2006 at 05:54:45am
I have heard that the minisport calipers flex quite a bit, it may be what you are seeing? I have the minispares 4 pots, and my pedal are a bit lower with these than with the S calipers I suspect, but my pedal is consistant and the brakes are good (with the correct pads!). |
27th Jun, 2006 at 09:46:54am
it also made a bit of differnce when i changed from green stuff pads to black stuff.
what type of difference... pedal feel or performance? |
27th Jun, 2006 at 04:57:47pm
well the green stuff felt shit and didnt work untill they got them hot and i mean HOT. the only time i locked the wheels up with them was at donninton park at a trackday!
My build thread..
28th Jun, 2006 at 12:03:36am
i got so pissed off with my 4th set of ultrashite minispares calipers i swapped them for a broken a+ engine and a hand chucking my engine back in |
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
28th Jun, 2006 at 08:25:56am
O/T who makes the best type of 4 pots? I will be getting a set of either 7.5 or 7.9 if they fit under my wheels.
28th Jun, 2006 at 08:45:34am
apparently KAD's are the best ones to get.....I wouldn't touch the minisport ones with a shitty stick personally after experiencing ant's. On 20th Oct, 2015 Tom Fenton said:
28th Jun, 2006 at 09:22:52am
odd, my minispares calipers are awesome Team www.sheepspeed.com Racing
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
28th Jun, 2006 at 12:50:16pm
Which calver bleeding method have you tried? The one where you pump the pistons out with the nipple closed and then push the pistons back into the caliper with the nipple open to force out air???
