| Home > Wanted > Help i need Hub spacers! | |||||||
784 Posts Member #: 912 Post Whore North Yorkshire |
25th Jun, 2006 at 08:20:30pm
In need of the spacer rings ( x2 ) from a set of front disc brake hubs! Its the open ring spacer that goes between the inner bearing and the oil seal. Shaft side.
I drill holes in everything..! |
27th Jun, 2006 at 09:12:41pm
are you fitting ball bearing type or roller bearing type[tinkin], either way everything should be in a bearing kit,
28th Jun, 2006 at 02:43:13pm
Yes Timkin.! The internal spacer is included. but its the spacer that keeps the inner seal the right distance from the bearing. Minispares are on back order so that means forever..! and i dont talk to that other mob. but on reading and looking further into it. as long as the seal is the correct distance away from the bearing it should be ok. fingers x.d.
28th Jun, 2006 at 09:54:52pm
iv'e never seen any kind of spacer you describe , i just put the inner seal in untill its flush with the body ,as long as the CV lip seal shoulder hits it somewhere it will do its job surely, back order usually meens never
29th Jun, 2006 at 11:36:09am
Thats what i,ve done for now.
30th Jun, 2006 at 08:55:21pm
that said ,i have been changing my bearings every 50 mtrs,lol. can't think why,
3rd Jul, 2006 at 11:31:35am
Hell....! that must slow you down over the 1/4 and be expensive to.
3rd Jul, 2006 at 07:04:18pm
On 03/07/2006 11:31:35 Si P said:
Hell....! that must slow you down over the 1/4 and be expensive to. Mind you, Bet you get crapy mpg too....! No ,i get bad gallons per mile,lol. carl |
