Home > Help Needed / General Tech Chat > converting to non verto
1976 clubamn
Member #: 400
Shrewsbury
after finding that i now need to replace the oil pump and possibly the shell bearings, i thought that i may as well change the clutch while im there.
afterreading threads about clutches etc, i find that many of you use the non verto type setup. so my question is this...
how do i convert my current verto system to a non verto system and does anyone have the parts to do this spare? if not a list of part numbers from good supplyers wood be very helpfull.
cheers guys
If it breaks... build a much faster one
You need:
Flywheel
Backplate
Clutch plate
Diaphram
Long clutch arm
Throwout plunger
Release bearing
Straps
Diaphram bolts
Slave cylinder
And, as the verto and pre verto flywheels have dufferent ring gears you might need a different starter motor.
Edit: do a search on 'clutch' on minispares.com, should pop up with most of the parts you need.
Wil
Edited by wil_h on 26th Jun, 2006.
