Home > General Chat > Water temp sensor, MPi or SPi
I know one fits straight away into the normal position and then i can hook up to my ecu. which one is it?
Infact i'll put it in a different place so i can keep my mechanical water temp gauge for now.
Moreover does it make that much difference when not running injection? just curious.
I need to nip to a scrappy to get some rover air temp sensors!
getting there slowly...
SPI is what you want, will not do much to you apart from control the fan switch, I've got one if your stuck
cheers mate. i'll get one from the motor factors.
fan, whats one of those?! ha ha! suprisingly i havent fitted it yet!
didnt think it did a lot on ignition only
MPI fits the normal threads, the SPI is a totaly different puppy having an olive and clamp nut sort of thing going on, need the right sort of hole and the one in the head is not the right sort of hole
http://www.minispares.com/Product.aspx?pid=32998
http://www.minispares.com/Product.aspx?pid=34159
you sure thats not the same as the seal on a normal sender?
the mpi one looks too small and i'm sure it is. spi still looks about right although i've not seen one and i'm guessing you have *smiley*
keep the info coming! need one at some point soon!
Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh Doh
ust been changing over the springs on the head and removed an ordinary sender. I was surprised to find that it is NOT 1/4" BSP i had thought, for all these years, but to find that it is actauly a similar type of fitment as the SPi sensor
Tried a SPI one and yes it does fit
Just me being my usual self and getting things Utterly wrong.
Accept my apologies and I shall never interupt a Factualy informing conversation with my dissinformation
Been working too hard on building the car and not getting much sleep, been working on it till 12 the past couple of nigts and 11 tonight. Well thats my excuse
