Home > Help Needed / General Tech Chat > plug types??
turbochargedstu
Member #: 908
gateshead
just wondered what plug rating people were running. got 6's in at the mo but i'm going for 7's at weekend. anyone know any reason why i shouldn't???
balls to the blower!!!
dont tell him unless he's coming to avon
andeh
Member #: 97
Near Daventry, midlands
*laughing*
Although i couldnt say anyway :(
Edited by andeh on 28th Jun, 2006.
Dangerous
Member #: 417
Depends what plugs they are on ngks I think a 7 is colder,but on champions it's hotter
(But don't quote me on that)
turbochargedstu
Member #: 908
gateshead
i always use ngk's. cheers nic!
I use NGK BPR8ES plugs out of an Escort Turbo, they have a shrouded electrode, which is nice.
I'd put 7s in as a minimum.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
for the MJ make sure its got resistor plugs *wink*
ALex
AlexF
AllanMcD
Member #: 414
Dalbeattie Scotland
ALex
Why I have run B7ES for over 10,000 miles with megasquirt and it goes a treat.
Allan
http://www.rabdunn.co.uk/
turbochargedstu
Member #: 908
gateshead
will do alex. i will be getting some 8's then as it will be getting the nuts caned offov it most of the time!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
ALex
Allan
Your wires arnt picking up any feedback then :cool:
Somtimes you can get all sorts of problem just down to the wrong plugs.
Alex
AlexF
AllanMcD
Member #: 414
Dalbeattie Scotland
I must need new plus soon so I will use BR7ES I didnt know it matered I made up sheilded cable for the megasquirt which I thought was all I needed.
Throwing away the dizzy was the best mod I ever did to my turbo motor.
im just using std metro turbo plugs, champion ones
will i see an improvement if i change to some fancy ones??
what are the std ones in a ngk grade
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
no improvment unless they are underperforming!
std is 6 iirc
I runs 8 or even 9s depending on spec.
Sorry I dont know the Chamion numbers at all.
Alex
AlexF
