Home > Help Needed / General Tech Chat > Dump Valve
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Hi i got a servo on my mini im about to fit a dump valve can i use a t piece between the servo pipe for the dump vale take off?
I cant use the big take off on top of the inlet manifold as i have blocked it off because it was in the way of my boost pipe path.
thanks
Nick
Member #: 154
Midlands
if you've blocked off the big servo take off on the manifold then where does your servo connect to?
Nick
Member #: 154
Midlands
and the dump valve needs to go on the other side of the butterfly anyway...unless you mean the trigger pipe? If so then drill and tap a fitting into the manifold for it.
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
The servo connects to the pipe that runs out the side of the inlet next to the water return. Ive blooked of the vacum in the top middle of the inlet.
so can i use a t piece of the pipe im using for the servo?
Yes you can 'T' into the servo pipe.
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Thanks mate just wanted to make sure it was a suitable vacuum thanks!
steveharwood
Member #: 1095
where can you buy the fitting for the dump valve vacume pipe to go into the manifold? thanks
Steve
