Home > General Chat > At long last
colas
Member #: 102
Pennsylvania USA
Well I have finally got my Megajolt installed and running. Well worth the change. Makes the car so much more responsive. I always had a flat spot which I thought was fueling, it;s not doing it now so I guess it was the distributor. I'm running the TT map which is what most people start with. Now i am looking forward to playing with maps.
A big thanks to Tom Fenton for the pully and bracket. Made my life so much easier what everything just fits.
Nick
JT
Member #: 637
Hertfordshire
so whats it like installing this megajolt then and getting a good map sorted, if you have never done it before?
cheers
josh
My build thread..
Excelent. The differance is amazing and well worth the effort. glad to see people using the TT map, we still do.
Josh: it is well worth doing, the TT map is an easy start for a turbo motor so you don't need to worry about a first map. installation is just a bit of wiring and bolting on some brackets and and stuff.
nic wrote a how to in the how to section, give it a look.
Edited by wil_h on 30th Jun, 2006.
colas
Member #: 102
Pennsylvania USA
All you have is a bit of wiring not really that bad. The installation guide by nic is great it helped me alot. And to make things easier give tom fenton a PM and ask him for a machined pully and a sensor bracket. The software is easy to use and there are a few maps availble on this site. The megajolt actually comes with a map and it made mine run better than the distributor and that wasn't even for a mini.
JT
Member #: 637
Hertfordshire
so its definatly the way to go!!
ill have to give it all a good read!
cheers
josh
My build thread..
colas
Member #: 102
Pennsylvania USA
I can't recommend it enough and for the price. It's cheap, real cheap.
Dicanio
Member #: 91
and alexf2003 can supply the megajolt unit
t3gav
Member #: 229
Gavin@minispares.com
kent
is the tt map a safe base map ie will it be ok to run any new engine in on it?
The TT map is pretty safe. If you are worried, just retard the whole map 2 degrees. That way you wont see more than around 26 dgrees at any boost.
t3gav
Member #: 229
kent
ah ok cheers mate *happy*
