Home > Help Needed / General Tech Chat > Running lean
jamesfawcett
Member #: 218
Bingley, West Yorkshire
hi all, my mot is tomorow dinner time, ive just had a first little drive in the mini but im worried because at certain RPMs it runs lean so i quickly put it back in the garage. Ive checked it on the colourtune and the lambda guage.
Im using a bog standard metro turbo carb and needle. Pot_dans bringing over a AAA needle tonite to try, is it ok to drive to the MOT on one of these? I think it will make it really rich so better until tuneup?
hippyinamini
Member #: 520
nr hull
hey up feebs, i think the A prefix needles are for the smaller hs4/2 carbs mate although im sure someone can say for sure. i know my turbo carb runs a pretty rich B needle to keep it rich untill it gets in for a RR but i cant remember what it is off top of my head. will have a gander at it tonight if i get a chance.
steve
doh! why did i start messing with it!
jamesfawcett
Member #: 218
oh ok!!
Im actually supprised because i thought that using a standard metro turbo needle would be too rich for a 998 turbo, because of the smaller engine. Can anyone explain why it isnt?
Also, has anyone ever found colourtunes any good? It seems such a rough way of tuning, the colour never stays constant it flickers yellow blue yellow blue all the time, and ive never seen a white (lean) on it on idle or a constant bunson blue, even when the lambda is telling me its lean at idle.
jamesfawcett
Member #: 218
To tune my mixture also, through the mixture screw, between fully screwed out and fully screwed in there is a peak where the revs rise. Is this the rough area where the optimum mixture is?
When you get to that bit, and you get a yellow flame for the colourtune, do you screw outwards or inwards to get the "bunson blue". Either way i turn it does get a little bluer, but still orange flicker.
Colour tunes are pretty rubbish as you can't check the mixture at any load, really only any good for checking idle m,ixture.
The mixture screw shoud be used for setting the idle mixture, then left alone. A file should then be used to profile the needle where necessary (unlesss you have a stack of needles to choose from) but DON'T file the idle part of the needle.
Dangerous
Member #: 417
Poodle down the mot place with the choke half out
jamesfawcett
Member #: 218
right! got it set really well now so its idling at 14.7 on the guage, when driving it runs a bit richer - goes to about 16 - 17.
however its really hard to set off, it really really struggles to get going, missing sometimes, its just really really slow and you cant press the throttle too much or it dies.
If you wait thought, slowly the revs rise, when it hits 3000 rpm its off!!! It sets off beautifully, lambda reading is good and no missfiring or anything , and when you change gear on boost it keeps going well, unless you go below 3000 rpm then it bogs down again.
Checked absolutely everything twice over, i can only think of it being a couple of things, the TT map im using not working on my car for setting off, or because my bleed valve (which is not adjusted to anything) is connected between the actuator and the plenum (because I have no outlet on my turbo) because of this i think that the bleed valve might be lowering the fuel pressure or something because the fuel regulator also sees this pressure? Is that possible?
Does anyone have their map i can use?
jamesfawcett
Member #: 218
The only other thing i can think is maybe an inlet gasket is leaking? I was tihnking this because on my NA mini when the gasket leaked it reved up fine stationary and sounded ok, but wouldnt set off. On the NA mini you could hear the gasket leaking though, but theres turbo noises all over that place on this engine!
Carl
Member #: 95
liverpool-on-sea
have you topped your dash pot up?
i just put 23 degrees in all the boxes when running in, just like having a fixed dizzy seemed ok, its now set up properly yho.
Does sound more like fuel than ignition. What is your fuel pressure like? you may have a slight flooding issue at tickover if it's a bit high, this will then take time to clear. Massive amounts of fuel can confuse the lambda sensor.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
DANGER !!!
14.7 is lambda =1 (stotiometric)
higher numbers = LEAN
lower numbers = RICH
On cruise 14-15 is ok
on power you want 10-12
over run can be 15+
Your going to melt your engine if you drive it setup as it currently is!!!!!
Alex
AlexF
jamesfawcett
Member #: 218
thankyou for the replies!!
Canceled the MOT and not driven it since. I dont know if the megajolt might have a problem though ive rewired the plug and everythings perfect, ive checked all the wiring and its all perfect. Im using the insulated wiring straight from the fiesta, but the RPM is always reading 467 in the megajolt software, and if you start the engine it crashes the software. Ive got another EDIS to try and another edis plug, and also im going to switch the wires round like hippyinamini suggested too even though ive checked it over and over now and it all seems right.
jamesfawcett
Member #: 218
Hi carl! will do that thanks for that, ill make a new map now with all 23's.
jamesfawcett
Member #: 218
hi will its at just over 3.5, ill see what happens if i lower it a little bit.
I found that with the heaters conneted to the lambda, it works perfect when warming up, but then i get a blank reading when the engines hot. With the heaters disconnected, it doesnt take long to warm up, but guage stays working all the time. Do most of you have your heaters on a switch?
sorry about all the questions
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
changing the base line fuel pressure doesnt effect the overall fueling by very much at all.
certainly I have tested 1 psi either way from a start point of 3.5 and recorded little difference.
Alex
AlexF
jamesfawcett
Member #: 218
thanks alex!! one less thing to try
Does anyone have their map i can use?[/quote]
feebes, id make sure your plenum to fuel pressure regulator is a dedicated feed ,with no t pieces or valve etc in it , you could take yuor boost pickup off the manifold instead .also have yuo disconnected the pipe that run round from the brass fitting just in front of the carb butterfly on the top of the carb ,and used to go round to the side connection for the mid range lean off function on the metro ?
also ,is it poss that yuor ecu is not getting a proper rpm signal ,and so sticking at 10 degrees until the 3000 rpm mark ,maybe the pickup is to far from the pulley?(this is probably impossible cos the ecu with no rpm would not make a spark would it ?) regards , robert.
Edited by robert on 2nd Jul, 2006.
