Home > 998cc > is T2 R25 fit?
iamhata
Member #: 1093
hi, i am kim , i am a class mini owner soon, my mini will be imported from japan to canada, it is a 1990 mini 1000, i want to put a tubro, and i saw a t2 r25 on ebay, but i am not sure will it fit to the car, because i read most people use t2 r5 turbo. what is the different between t2 r5 and r25? is it same? should i buy it ?
thanks a lot
Dangerous
Member #: 417
Renault 5 is 1400cc engine
Renault 25 is 2500 cc engine
Therefore would expect quite a bit of diference
ahhh, just clicked as to what R25 is (durrr), big barg of a car.
As captain danger says, probably not a good choice, just too big.
miniallsort
Member #: 1131
would a t2 turbo fit a 988 i am also interested in a turbo converstion
any advice ????
cheers
t3gav
Member #: 229
Gavin@minispares.com
kent
yep, some people are also using the t3, try the search button and get reading *wink*
miniallsort
Member #: 1131
there is not much info on the search button
do u no of any sites i could get some info on 988 turbos. from ??????
cheers miniallsort
clubby_turbo
Member #: 403
sydney Australia
this one. im half way through turboing my 998 engine (without any previous experience with mini's at all) and i'v never used any other site, the information is here, you just hav to look long and hard. if there is anything you cant find, ask about it and someone will tell you the answer or somewhere u can get the answer from.
chris
998 turbo
miniallsort
Member #: 1131
what would be a better fit a t2 turbo or a t3 turbo???
Turbo Shed
Member #: 30
Epsom, Surrey
T3 requires the bulkhead cutting and welding then its a bolt together job with parts from the metro turbo
T2 is simple with the Mirage kit with no cutting and welding
do it yourself T2 or T3 will require lots of welding and fabrication, and can be a pain in the backside.
if you dont have all the metro parts consider the mirage kit.
Slightly OT but I didn't realise your were going for a 999, if it's the bore and stroke I think it'll be an interesting engine. I once meet a chap who raced a NA one back in the days of the 1L classes and it reved like there was no tomorrow. Also it'll give you a good choice of pistons. The down side is the block and crank won't be cheap.
Interesting, I presume you're getting the pistons at mates rates judging by the price. Got to say I can see the sense behind boring out an 850, both in cost of purchasing the engine and the fact that they can be rebored with out pushing them over 1L. Will this engine be running the K series head or is that a no go as far as the hill climbing runs are concerned?
Thanks :) Mine isnt' the engine you think though, it's not a cooper 970 bored to 999, its an 850 bored out to 68.3 ish mm using custom pistons. I scored a 11,000 mile 850 engine for £13 on ebay, and it's internals, crank etc are as new! So I'm hoping it will be fairly cheap. The roller cam is the most expensive part as it has to be ground on a custom virgin blank. The roller lifters are adapted aftermarket parts from a US V8. Even the custom forged pistons are around £240, 1/2 the price of omegas etc. Cubic enginuity rather than cubic cash :) The whole thing will be around £1400 including the dry sump set up. That doesn't include a box though.
[/quote]
What do you do with thrust washers for the crank?
That's my thought. I don't think that std size 850 thrusts would take a grey diaphragm for long.
On 07/07/2006 12:57:09 mini1071s said:
Again though, I'd say unless there is a specific reason, go for the 1275 as a T2 on a mirage kit on that is a storming peice of kit. Look at Nic's car for proof of that!
hehehe smugness!!! thanks
clubman_dan
Member #: 142
Winchester
hahahaha loving that dramatic music on the website for the pistons! lol
Ha ha ha ha, just clicked to hear the piston music, it came on quite loud on my computer and my cat shit himself (not literally thankfully) and is now hiding under the desk!!!!!!!! LOL!!!
Just realised that you would have bothered with a roller cam if you were going for a K series head. Also just found the thread on your 850 engine so I feel like a right idiot.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
hi yeah mines running now, mines a 1040cc with a T2 turbo on it and a standard turbo head and running really well!! not sure of power yet but its only running 4psi and its a hell of alot faster than my 1.3 turbo was at 6psi, the boost kicks in really early and strong for 4psi and its nice and drivable. Having fueling problems at the moment think its the pressure regulator.
Mines built as a road car and not going to be running much more boost, dont need to, i have my rev limiter set to 5000rpm (its on megajolt) even though the engines built to rev high, im really happy with how quick it is!
