| Home > Help Needed / General Tech Chat > suspension setup | |||||||
53 Posts Member #: 1013 Member OXFORD |
4th Jul, 2006 at 01:13:02pm
rite im probly sounding like i know nothing at this point but bear with me, im learning! |
4th Jul, 2006 at 01:30:40pm
the metro has hydragas suspension, basicly the same as hydroelastic except the springing element is a nitrogen filled resovoir thing.
4th Jul, 2006 at 03:22:17pm
sounds like the units need pumping up as mentioned.
4th Jul, 2006 at 03:24:37pm
Yes, indeed the front shocks on a metro are mini rear items, I once fitted adj spax to the front of an (NA) MG Metro and it transformed it.
4th Jul, 2006 at 03:33:30pm
so how (easily) can the suspension hydrogas be recharged or refilled. is it a job for MG garage or does sum one have a unit to do this?
4th Jul, 2006 at 03:37:55pm
so the front shocks on a metro (inc TURBO?) are same as the rear shocks on a mini.
4th Jul, 2006 at 03:52:26pm
pumping up the suspension is a 15min job, providing you have the special pump. some Rover dealers have these as the also used the hydrospastic syspension on the MGF
4th Jul, 2006 at 06:17:15pm
that mite be quite refreshing in this weather! :cool: |
4th Jul, 2006 at 06:51:12pm
you can knock a pump up using a grease gun. details under suspension on this link.
5th Jul, 2006 at 11:49:18am
No modification needed, they bolt straight on.
5th Jul, 2006 at 12:55:11pm
Yes toms right the shocks will bolt straight on,
5th Jul, 2006 at 05:46:17pm
you luv em by the sounds of it!
