Home > Help Needed / General Tech Chat > rollcage
lil stu
Member #: 837
rugby
ello ello ello
ive bought a 2nd hand bolt in rear saftydevices rollcage
and the guy said it doesnt come with the plates.
what is it that these plates are for?
and does anyone have any?
ttfn
spreading the loads on the floor. fairly simple to make up, think the size for FIA status is 3mm thick and 120mm square
Carl
Member #: 95
liverpool-on-sea
if you ring saftey devices thell sell you a fitting kit which includes all the nuts, bolts and washers and the weld in plates, be warned not cheap tho*smiley*
Speak to the roll centre or safety devices as they will sell you the plates, or as above make them up.
They need to be welded to the floor where the cage bolts in.
lil stu
Member #: 837
rugby
cheers guys i will try making them
lil stu
Member #: 837
rugby
ello again,
im havin some problems gettin the roll cage in,
ive tried searchin but cant find any relevant topics
do i need to cut out the rear pockets as i would like to avoid it if possible.
Cheers for your help stu
No you should not need to cut the pockets. Remove all front and rear seats. Position the rollcage rear hoop where the front seats would be, lying on its "front", with the rear stay legs up in the air. Then you need to "roll" the cage from where it is, into the upright position, hooking the feet over the rear pockets into roughly the right position. You may find you need to use a ratchet strap around the legs to pull them together slightly to get past the B pillars.
lil stu
Member #: 837
rugby
cheers tom got it in
clubminiflip
Member #: 54
nr coventry
sorry for the hi-jack, i have a six point cage, i think its a satety devices & wanted to know if i can get doorbars for it as mine does'nt have the mounts on the parts i have if ya get my vague meanin
Carl
Member #: 95
liverpool-on-sea
the saftey devises door bars clamp around the cage so yes you should have no probs getting them most mini suppliers stock them*smiley*
your right carl but.........
these plates "if not painted before fitment" (will rust!)
i made mine out of 5mm satainless steel! the
underside ones
