Home > Help Needed / General Tech Chat > minispares rads
Gibbo
Member #: 34
Decided yesterday that my intercooler wasn't in the best place, cos I was running a Metro rad.
So I ripped it out and re-routed my intercooler.
I now need to revert back to a side rad, and was thinking about the 2 core minispares one.
Are these any good, or is there better for similar money?
When I ran a Std. mini rad before, it tended to get way too hot on the moterway when giving it some.
The rad was old though, so might have been blocked even though I flushed it for ages.
1310turbo
Member #: 41
i run the minispares 2 core rad, and have had no problems with it at all. my engine is in fairly mild state of tune at the moment, std boost, std head etc, so i dont know how they cope on a high output turbo engine. best off hearing advice from the faster boys
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
TurboHarry
Member #: 115
Austria, near Vienna
Hi Gibbo!
I also have the front Metro Rad and the intercooler sideways - but I made a nice duct to the intercooler to ensure good flow! Even in very hot summer temperatures seldom I have more than 80?C water temp.! And never exceeded 40?C inlet temp in the plenum on a 30?C day!
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
Gibbo
Member #: 34
Yeah, I thought of ducting it, but things were starting to look messy.
I've got a removable front on my car, so even though it seem easy to fit stuff, you end up with loads of strange brackets to make it fit.
Plus if I want to increace my intercooler size in future, I don't think it would be possible.
I wouldn't mind seeing a picture of your setup though, always nice to see how others do things.
Edited by Gibbo on 4th Apr, 2004.
TurboHarry
Member #: 115
Gibbo, I asked Jim to post a picture because I can't do it on my computer! Have a look!
The intercooler is from an Alfa 164 Turbo and should be good for 200hp (A Corky Bell Calc.)
Here you go mate
http://mini.lyons-it.co.uk/harry/100_0011.jpg
Alex - edited to a link as the pic is HUGE and I can't see it on my screen *tongue*
Edited by AlexF2003 on 5th Apr, 2004.
gregor
Member #: 98
Slovenia
TurboHarry, I always like to see under the bonnet of other minis. looks interesting. Do you have some more pic? have you been with that mini on IMM2003 in Italy last year?
Edited by gregor on 5th Apr, 2004.
TurboHarry
Member #: 115
Hi Gregor!
Yes I have been there - have not seen a lot of TurboMinis! Yes, i have more pics, the one Jim posted for me is very old, a lot of things have changed since then! I can't post pictures on this forum - give me your E_Mail and I will send you more! Harry
gregor
Member #: 98
Slovenia
Hi Harry,
When I saw pics of your mini I recognize that I have seen it. I remember your mini from there.
pics are welcome. my email is gregor.tm@volja.net
gregor
TurboHarry
Member #: 115
Yes Fab, and with a duct you can go down with the air inlet area to 1/4 of the core area and it is still more efficient than just have the IC standind direct in the air flow!
