Page: |
Home > General Chat > Homemade Hydrolastic Pump | |||||||
207 Posts Member #: 193 Senior Member Aylesbury |
10th Nov, 2006 at 09:22:29pm
Has anyone ever made there own hydrolastic pump and if so how did they do it. I am thinking of having a go. Maybe use a Portapower as a pump or a master cylinder with a one way valve, what do people think.
10th Nov, 2006 at 10:07:00pm
have a look in this topic, i posted a link in there the other day to a website where some one used a greasegun.
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
10th Nov, 2006 at 10:19:19pm
I built one using a heavy duty grease gun he kind that sits in a drum I never filled a car but did pump mine up a bit then let it down it worked ok.
2521 Posts Member #: 417 Post Whore Swindon |
10th Nov, 2006 at 10:31:50pm
I got a home made one and it's next to useless,prob ok for a mini as they are lower pressure than a mini.
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
12th Nov, 2006 at 09:18:24am
I made one from a brake master cylinder. It works ok, the problem with mine is i used tubing thats only rated at 10bar so if i try to pump it up to relly high pressueres it just flexes the tube and dosent push any fluid in!
12th Nov, 2006 at 01:56:40pm
Try pumping it up with the car jacked up.
Page: |
