| Home > Help Needed / General Tech Chat > Wheel Camber | |||||||
332 Posts Member #: 483 Senior Member Merthyr Tydfil |
14th Mar, 2007 at 06:31:24pm
Hi all
14th Mar, 2007 at 06:54:06pm
Quickfit and modded minis, Take it to Burger King, they will have more of a clue..
14th Mar, 2007 at 07:01:19pm
6.1/2 degs if it was a V8 holden. |
14th Mar, 2007 at 07:02:12pm
no just standard ride height although i have had Adjustable Spax fitted
14th Mar, 2007 at 07:48:58pm
cant get shitter than a quick fit fitter
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
14th Mar, 2007 at 11:17:20pm
Qucik fit, total BOC would rather leave my car in the hands of a pack of monkies, sandard of work would be so much higher!!
Edited by shane on 14th Mar, 2007. |
14th Mar, 2007 at 11:24:34pm
15th Mar, 2007 at 08:26:53am
I just upgraded to 4 pot calipers and fitted new wheel bearings.
15th Mar, 2007 at 08:37:17am
the fitting of the turbo and the suspension are unrelated.
15th Mar, 2007 at 08:45:11am
metro hubs? do they not cause neg. camber? |
15th Mar, 2007 at 09:29:36am
On 15th of Mar, 2007 at 08:45am miniminor63 said:
metro hubs? do they not cause neg. camber? My thoughts too but I think they cause positive camber. On 7th Nov, 2008 Nic said:
15th Mar, 2007 at 04:07:27pm
no its a mini hub the original of the car. Its only on the passenger side.
15th Mar, 2007 at 04:15:16pm
Oh only on one side, right well in that case something has probably worn/failed. As said worn knuckle cups will drop the right height but shouldn't affect camber that much. Are you double sure there's no play anywhere?
15th Mar, 2007 at 04:30:26pm
could be the top arm pin/bearings or bottom arm bush |
19th Mar, 2007 at 10:04:56am
Its Just the One side it does look like something has collapsed the way the wheel is facing in. There is def nothing lose or no play in anything. I am going to get my new high los and knuckle joints fitted this weekend hopefully this will solve the problem.
19th Mar, 2007 at 10:58:42am
if its already got hi los in, you will probably get away with winding them fully in, usually gives enough room without having to compress the donut.
19th Mar, 2007 at 11:03:00am
You *could* just cut part way through the aluminium trumpet and hit it with a chisel to collapse it enough to get it out but compressor is the best and safest. I blew the threads on one of my cones so had to do it as mentioned. Well actually Dad did it, he has no fear (or sensation from the elbows down) and I don't like being around compressed springs. On 7th Nov, 2008 Nic said:
19th Mar, 2007 at 01:27:35pm
I think Ill take it somewhere! I dont want to mess it up |
17th Apr, 2007 at 01:10:00pm
Sorry to Bring this up again!
82 Posts Member #: 939 Advanced Member |
17th Apr, 2007 at 01:52:34pm
they are the same top and bottom. are you using the correct ball joints? they changed at some point. you need early ones to fit mini arms. |
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
17th Apr, 2007 at 02:05:13pm
yeah there is a difference in the diameter of the pin, but i would think you would get a knocking sound.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
17th Apr, 2007 at 03:01:23pm
I havent hit anything!
17th Apr, 2007 at 04:28:37pm
sounds like the rack could be goosed. i know that when using the metty drive flanges etc it changes camber, but also kingpin inclination (will have to find me examiners books to find exact phrase but am sure that was it !) and the geometries need to be set via adjustable bottom arms. the whole shabang will be adgitated by the trackrod/rack IMHO i have seen it many times with minis using vented systems off mettys, if it is desperate ie cannot wait until thursday, i will drive to work and get me manuals regarding drive assemblies (defects and settings) and see if i can find the correct terminology, i am sure someone on here will correct me or remind me what i am trying to say......if u catch me drift.
Edited by Richie on 17th Apr, 2007.
17th Apr, 2007 at 04:58:49pm
yea the car pulls to the left alot. all the wheels are blanced but it pulls cause of the angle its on. I think my next option is to change the steering rack.
17th Apr, 2007 at 05:44:22pm
I've run mety vented set-ups (on Mini uprights of course) several times without a problem .... it can be made to work well Edited by RogerM on 17th Apr, 2007. Every day is a school day ...........
