| Home > Help Needed / General Tech Chat > Possible over fuel | |||||||
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
3rd Aug, 2007 at 12:48:25pm
Car doesnt seem to rev past 5k in 3rd gear so changing to fourth it wont pull at all it just splutters and hold s back. Ive done a search about possible causes and in one of the topics it says either fuel pump or benross said it could be float needle valve which needs drilling out. We tried this and we couldnt get it to seal. I was told to check this you take the dashpot of and wind up the reg and no fuel should come out the carb, firstly is this correct. So instead i bought the part from avon bar and it still leaks fuel from the carb wen you wind the reg up. Took it for a drive anyway and doing the same as before and wen you brake hard the engine cuts out. you then need to turn the pump of and fire it over for a few times to get it going and then switch the pump back on. I spoke to avon bar and he said the fuel would come out of the carb wehn you wind the reg up he said it is normal, i breifly explained what problem i was having with the car and he said the pump may be to powerful as i told him it was a new pump but it was a injection pump, believed tobe 10 bar can the pump be to powerful and would it cause this problem? if not what could it be? i done a flow fuel test and it was pumping out a litre in 17 seconds.
3rd Aug, 2007 at 08:51:40pm
firstley you need to set the fuel pressure to 4psi with out boost
3rd Aug, 2007 at 10:14:03pm
4th Aug, 2007 at 09:53:36am
he we have managed to turn the pump down abit by turning it to 9 volts. could this still be the problem? it didnt have any effect on the car what so ever.
4th Aug, 2007 at 10:06:51am
4th Aug, 2007 at 07:20:12pm
yea but what i mean is if the pump is to powerful and the flow is to much on it then the return wouldnt be able to get away as quick so resulting in a build up in the reg, is this possiable.
5th Aug, 2007 at 10:09:47am
firstley!
Edited by BENROSS on 5th Aug, 2007.
6th Aug, 2007 at 01:12:14pm
sounds like my issues when it was far too rich.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
6th Aug, 2007 at 02:02:08pm
try and find bud666's thread he posted just before riv run, very similar issues. Turned out to be the crap in-tank filter. Worth checking out... |
7th Aug, 2007 at 02:54:48am
On 5th of Aug, 2007 at 10:09am BENROSS said:
firstley! you must have an independent fuel return line. if you Teed in the return line back into the inlet this may well be your problem Plenty of us are running Tee's with no problems, me included. But maybe with the high capacity of your pump you are running into cavitation or airation of the fuel which causes the problems. Rather than a T piece I used a fair sized fuel filter that had 2 inlets reasoning that it acts as a small reservior. maybe try that? or even drop the T and run the return into the fuel filler for a quick test? but be careful!! Terry Edited by Turbo Tel on 7th Aug, 2007. website:- http://www.terryhunt.co.uk
7th Aug, 2007 at 07:27:47pm
have changed the return line is now plumbed into top of the tank. adjust mixture slightly but i really dont think adjusting the mixture will make that difference cos it really does just stop pulling and its in same revs all time. its not the filter in the tank thats blocked because i dont have one in their anymore. thanks for your suggestions guys. its stilll the same though and i not sure what else to try. i obvouisly need to change the pump next to a proper metro pump or similar. their some cheap ones on ebay are they any good. |
7th Aug, 2007 at 10:32:30pm
go for the pump the right one
8th Aug, 2007 at 09:47:59am
ok ill source a new pump then. i hope this solves it.
8th Aug, 2007 at 10:08:10am
tried looking for pumps, is this the right one?
8th Aug, 2007 at 10:22:14am
T piece trick. Do a search.
8th Aug, 2007 at 12:18:55pm
The timing didn't change with the megajolt you say? So it is running in fixed limp 10 degrees mode all the time? This will not help matters, you need to get it working properly.
9th Aug, 2007 at 10:45:48am
sorry guys i think i may have suss it out. But now i have lost my clutch. bloody release bearing has gone so ill fix that today and try car again but basically i advance the timing as i checked what timing it was running. i advance it by 1 degree and it made a difference in 3rd gear didnt try four as i was on my way home from gettin pissed off because the bearing gone. so ill try car again and advance it maybe another degree ontop that see how it goes. it was running 26 degrees from 3.5k up to 6 k. so i changed the 5k boxes to 27 and tried that. is it safe to do that. to be fair 26 didnt seem high enough? what do you guys think ill keep you posted. cant believe it could just been timing all along. |
9th Aug, 2007 at 10:13:04pm
10th Aug, 2007 at 09:42:23am
it went for a rolling road and stuart couldnt get it to rev past like 4k either in 4th gear. so thats why when i advanced the timing another degree it went bit better surely he should have known to try that. it is odd he said when it was on rollers a few weeks back that it was pulling really well up to 4 k then just dipping and stopping. he reakoned cam timing or engine not being run it hard enough but ive never heard that before. plus the sam timing is ok! |
8 Posts Member #: 1322 Junior Member Egham, Surrey |
10th Aug, 2007 at 10:44:38am
Have you removed the filter off the pick up pipe in the tank and running an external pump pre-filter? It doesn't sound like a timing issue with 26 degrees those rpm. The extra advance you added may just of momentarily improved the problem. |
13th Aug, 2007 at 11:19:14pm
yes i do not have a filter in the tank and i do have a filter before the pump.
28th Aug, 2007 at 09:24:00pm
Still having problems. i have bought a new regulator and this hasnt fixed the problem although it has stop the fuel gauge flucuating. have tested the pump again and again under load and normally doing a flow test also and it seems really good. i have also put a restrictor in fuel supply and has made no difference. surely it cannot be the pump side of things as the pressure is reading good. about 16psi fuel pressure and running about 12psi boost. when it gets into high revs in 3rd the car stops accelerating still withing the space of about 200rpm it stops completely pulling and the carb gets loader and deeper like its not getting enough fuel now. so maybe its the needle or something like that what do you guys think as i tried alot of other things.
28th Aug, 2007 at 09:37:01pm
Stuart was spot on with my MJ? Did you check the timing with a timing light to make sure the MJ is reading TDC when it actually is.
Edited by matty on 28th Aug, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th Aug, 2007 at 09:22:12am
probably waaay off here, but what pipe have you got going to the inlet of the turbo? If it's the standard metty turbo one, it detirorates over time and crushes under boost. Might be that... |
29th Aug, 2007 at 09:27:40am
Ah too true could well be that....
turned out there was a whole load of Audi's fitted with the wrong spec hose!
