| Home > Help Needed / General Tech Chat > Turbo oil feed question(s) | |||||||
249 Posts Member #: 513 Senior Member Sheffield |
13th Aug, 2007 at 09:09:43pm
Am I correct in thinking the part on the left is an oil feed for the turbo?
13th Aug, 2007 at 09:34:42pm
Yes it's the oil feed. It should reach the oil pressure takeoff with ease if routed correctly. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
13th Aug, 2007 at 09:41:02pm
Try www.minipart.co.uk they do a selection of braided hoses. |
13th Aug, 2007 at 10:14:03pm
hmmm, i ordered a turbo oil supply from minipart.co.uk, the kit came missing bits, and the threads for the block and turbo banjos were wrong. Ended up having to buy the missing/incorrect bits from avonbar.
13th Aug, 2007 at 10:24:21pm
Yep definitely sounds a little worrying considering I'm not 100% sure what I need. Just found this thread
Edited by andygardner on 14th Aug, 2007. |
13th Aug, 2007 at 10:50:29pm
ive got one you can have got £95 LOL "Turbo's make torque, and torque makes fun"
13th Aug, 2007 at 11:01:41pm
Oil return is about £15 ish from Avonbar. (thats only the silicon hose) you'll also need the fiting on the block! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
13th Aug, 2007 at 11:08:24pm
Your ideas are intriguing to me and I wish to subscribe to your newsletter! |
13th Aug, 2007 at 11:10:53pm
That makes more sense, couldn't see the return listed on their site.
13th Aug, 2007 at 11:17:27pm
most use the std metro turbo item i guess, but making one from a fuel pump blanking plate should prove easy enough, its only a pipe sticking out of a plate
13th Aug, 2007 at 11:26:04pm
Ahh so really I just need to get a T-piece fabbed up for the block and same for the feed on the turbo and blanking plate for the return.
13th Aug, 2007 at 11:45:44pm
13th Aug, 2007 at 11:47:37pm
I made my own as I lost my original one, then lost the one I made, then when looking for one I made, found the original one I lost...PMSL Edited by matty on 14th Aug, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Aug, 2007 at 08:38:35am
get the stuff from Avonbar.
14th Aug, 2007 at 12:51:18pm
Cheers guys, advice taken.
14th Aug, 2007 at 01:08:11pm
I plumbed mine in like that and found that the more air I bleed off the less boost it showed on the gauge (but I was actually running more boost) Edited by matty on 14th Aug, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Aug, 2007 at 01:33:57pm
Bosst gauge shoud be fed from the manifold Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
14th Aug, 2007 at 02:11:54pm
yeah, you'll only see boost no vac if it's before the throttle butterfly. Like matt says, use one outlet for actuator and the other for bleed valve. |
14th Aug, 2007 at 03:54:02pm
edit: double post Edited by andygardner on 14th Aug, 2007. |
14th Aug, 2007 at 06:03:59pm
edit: triple post Edited by andygardner on 14th Aug, 2007. |
14th Aug, 2007 at 06:04:40pm
edit: don't post then go back and forth in your browser! Edited by andygardner on 14th Aug, 2007. |
14th Aug, 2007 at 07:18:40pm
edit: groan, delete delete delete.....!!!! LOL
14th Aug, 2007 at 08:28:02pm
Whilst on the subject of oil feeds what size do we reckon is needed for a turbo? would -3 be big enough bore?
Edited by Joe C on 14th Aug, 2007. On 28th Aug, 2011 Kean said:
![]() 124 Posts Member #: 1428 Advanced Member Cleveleys |
14th Aug, 2007 at 10:16:39pm
I had Hose solutions make a feed hose up, as i'm using a IHI RHB5 turbo, i found them on ebay
998 turbo in progress.... DONE..........KNACKERED LOL |
15th Aug, 2007 at 08:25:39am
i poped along to thinkautomotive and found them very helpful |
