Home > General Chat > Cold Weather Gains
Relitively, what would gain more power in cold weather: An NA engine or a turbo.
My thinking is that a turbo will gain more, firstly because any intercooler will cool air more and because the larger volumes of air involved in charged engines means that any increase in density will have a greater effect.
And I don't want alexF spouting on that Cosworths lose power in cold air as they get too close to detonation (or something)
Sounds about right to me, more moisture in the air helps too!
You can get the carb to ice quiet easily if you haven't got a heated manifold!
Cosworths don't have those kind of problems *tongue*
I think that the power gain due to cold air will be directly proportional to the change in air density.
You can calculate it by working out the percentage decrease in absolute temperature of the air entering the cylinders.
So the increase in density from 30 down to 20 degrees C is as follows:
(273 + 30)/(273 + 20) = 1.034 i.e. 3.4% increase.
Obviously, for a turbo the temperatures are higher but the same rules apply.
This is why the intercooler makes such a big difference in power output, particular at high boost.
So you're saying NA and turbo will be the same? so a 100bhp engine in your sinario would gain 3.4bhp whether it was NA or turbo?
It is not as simple as that because it is dependant on the air in the inlet manifold.
For NA, broadly speaking, you would get the 3.4%. However if the air is heated in the engine bay before getting into the manifold, then the gain will be less.
For Turbo, assuming intercooled, the gain would be less. If the intercooler is 80% efficient, then the 10 degree temperature drop in air temp will result in an 8 degree drop in the mainfold.
But the air temp entering the turbo will have been 10 deg cooler in the first place, so the charged air will be cooler before it gets to the intercooler.
Yes, you are correct.
The turbo heats it up the less and then the intercooler has less to do.
I've just ran some detailed calcs and came up with a zero increase on a turbo. I'll PM you a spreadsheet.
I think that the real gain comes from improved intercooler efficiency due to the lower ambient, but I don't know how to calculate that.
Well, I've checked my calcs.
My spreadsheet did not show any power gains because it calculates power purely from air volume flow. It does not take account of intake temperature - something to fix in the future.
However, it does show that the air temp after the intercooler has dropped from 50 deg C to 39 deg C.
This equates to a 3.4% increase in density and hence holds up the theory.
Excellent, another myth busted.
I think the general consensus was that a turbo made more gains (as I thought) but not so.
Thanks very much.
like when you drive on foggy mornings..seems to drive a bit nicer,d ask vegard,doesnt he live in antartica?lol
Moz
I'll take BIR1 out when it's minus -20Centigrade... I might struggle with grip though..
I'm thinking about an aircon system to help the intercooler. Should have the same effect.
axel a pal of mine with a jap import mini
was telling me about this idea also..h said it would work well,but hen there is power drain to make power,like on the pump...
Moz
something to add ,
if the mass flow through the engine rises due to the air being denser ,then the compressor map position changes ,
if the boost reference is on the inlet manifold where it should be ,so the new pos on the map may be a point of greater efficiency , so make more power ,
the turbine will need to do less work per psi and so the gate will bypass more and turbine back pressure will drop .
also moisture content in the air ,will increase cooling effect of the ic as it rises ,so colder MOISTER air will make more charge temp drop ..
also colder air is cooling the outside of the compressor housing and all the piping ducts etc more and reducing under bonnet radiant heat ,which all adds up .
also a lot of engines are dynoed with the bonnet up and so run a hotter underbonnet temp on the rd ,so the timing can be a little advanced for that situation ,the colder air brings the underbonnet temp closer to the rr temp and so the timing becomes closer to correct ...um .think thats it lol
oh no another thing ,all the positive points about water inj come into play to a certain degree with high humidity ,so smoother combustion ,effective octane increase etc etc .
oh axel there a company in the us selling an air con assisted ic ,iits on a mustang site i think .
Jason G
Member #: 1459
En-suite user
Braintree, Essex
You notice the difference with old n/a diesels a hell of alot. upto 10mph in the transit.
On 19th Jan, 2010 wil_h said:
danboy
Member #: 1381
regarding the intercooler efficiency, if the turbo outlet temp remains the same the inlet manifold temp will be less as the rate of cooling is increased because of the greater temperature difference across the core.
ie lower ambient = more power.
regards.
Dave
I would say if you have a turbo car with out an intercooler you would gain a more % age. other than that not sure mate as our cars as you no can't add more fuel for the cold weather, wheni drive mine this time of year it feels much slower!
Edited by Miniwilliams on 31st Oct, 2007.
There was a thread titled (heated manifold) The carb icing up was seen as a pretty bad thing. I was thinking of fitting a seperate Rad setup with a small pump and rad to the manifold to cool the air/fuel mixture as much as possible? Would this be a worth while thing. I already have all the bits lying around, cant hurt to try it out i suppose.
Mike I would say in the winter months, you need some heat to be around, to stop it icing up and to help it run at a more normal temp.
I thought about the aircon idea, but then thought about the extra weight of pumps, Rads, coolent and the power lost through driving it all and didn't seem worth it! ;ohwell:
Iv'e been thinking of using some kind of "jacket" around the IC and pumping a liquid through it that will evaporate drawing the heat with it, and condense back into a kind of catch tank, to be pumped round again.
Great idea for the summer matty, NOT for this time of year!
True..this time of year is for engine rebuilds. lol *laughing*
Are yes there is that one to. I really should pull me finger out and take mine off the road.
I really should pull my finger out and get mine back on the road..pmsl *laughing*
lol *wink*
