| Home > Help Needed / General Tech Chat > *UPDATED* I FOUND MY BOOOOOOOOOST! | |||||||
365 Posts Member #: 1211 Senior Member Working up the BHP ladder. |
26th Nov, 2007 at 07:54:45pm
Hi guys,
Edited by 1380turbo on 3rd Dec, 2007. |
26th Nov, 2007 at 08:06:54pm
Your cam timing set right? On 19th Jan, 2010 wil_h said:
26th Nov, 2007 at 08:11:56pm
Sure is matey. Checked that again when the carb went poo.
26th Nov, 2007 at 08:31:06pm
No probs. Got one coming.
26th Nov, 2007 at 08:44:34pm
probably yer, As sonn as you lift the clutch to engage 1st its pops then dies |
26th Nov, 2007 at 09:27:51pm
if you are sure that the cam timing and ignition timing is correct you will find your fueling is light year out!
26th Nov, 2007 at 09:55:00pm
On 26th of Nov, 2007 at 09:27pm BENROSS said:
if you are sure that the cam timing and ignition timing is correct you will find your fueling is light year out! more than likley too WEAK! ![]() Cam timing......check! I checked the mixture with a colour tune thingy once it had warmed up and if anything it looked a bit rich, plug came out black and sooty. Ignition timing.....dont understand why the marks never lined up? If i go by the original mark its running about 35degrees ATDC?????? Confused.......? I sure as hell am. lol
26th Nov, 2007 at 10:41:00pm
But didnt you say the original mark was some 40deg out ? 9.85 @ 145mph
26th Nov, 2007 at 11:09:22pm
If the timing mark on the pully has moved, Its goosed, get a new one soon or you may find a half kilo mass of steel flying around the engine bay On 26th Oct, 2004 TurboDave16v said:
27th Nov, 2007 at 12:11:19am
27th Nov, 2007 at 12:29:43am
On 26th of Nov, 2007 at 10:41pm stevieturbo said:
But didnt you say the original mark was some 40deg out ? I did but its tricky to tell exactly how far out with the mark that far off the timing pointers. i will pull it apart and have a closer examination of the pulley. Will report back. Thanks guys |
27th Nov, 2007 at 01:41:09am
40 deg is a HUGE amount though.
27th Nov, 2007 at 10:01:12am
There is an A series pulley with the mark in a different position - I have one and it confused the hell out of me for a while. Never have worked out what it is from though! |
27th Nov, 2007 at 10:37:16am
I think I remember seeing an inline engine with the marks on the otherside of the engine.
28th Nov, 2007 at 07:09:33pm
Avonbar tell me thats the right pulley and that the old cooper S ones had the timing pointers in a different place.
28th Nov, 2007 at 08:55:23pm
So what sort of timing are you seeing at 3000rpm etc ? 9.85 @ 145mph
28th Nov, 2007 at 09:59:24pm
29th Nov, 2007 at 05:22:15pm
OK, couple of thoughts on this,
29th Nov, 2007 at 05:28:20pm
My part throttle lean off pipe wiggled it's way off once and I had the exact same symptoms.
In the 13's at last!.. Just |
29th Nov, 2007 at 08:39:49pm
Ahhh some good things to check there guys cheers.
Edited by 1380turbo on 29th Nov, 2007. |
29th Nov, 2007 at 09:14:56pm
29th Nov, 2007 at 10:03:13pm
ahhhhhh something to investigate.
29th Nov, 2007 at 11:09:42pm
search for the T peice trick of turbo
30th Nov, 2007 at 02:49:12am
My engine alway ran fine when blown between 2-3. Of course it was noticeable, but still totally driveable.
1st Dec, 2007 at 03:03:21pm
Ok here is the update folks. Pulled all the bits n pieces off the carb to check the right gaskets were fitted and they were ok. Checked the dizzy and it advanced upto about 20 degrees but still no joy.
Edited by 1380turbo on 1st Dec, 2007. |
