| Home > Technical Chat > Detonation and Compression Ratio | |||||||
23rd Dec, 2007 at 10:52:50am
I've been looking at the factors causing detonation in a turbocharged engine. Principally to try to decide on a compression ratio for my K100 Turbo.
23rd Dec, 2007 at 11:51:27am
i think you are on the borderline on pump fuel ther paul ....... be intresting to hear how you got on
23rd Dec, 2007 at 12:57:33pm
We need to consider the dynamic compression ratio rather than the static compression ratio, and that is a factor of the cam being used
Edited by Sprocket on 23rd Dec, 2007. On 26th Oct, 2004 TurboDave16v said:
23rd Dec, 2007 at 01:41:37pm
You both appear to have missed the point. You've read 10:1 and 10 psi and sucked your teeth.
23rd Dec, 2007 at 01:50:50pm
What about the ambient air temp having a direct effect on both inlet charge temp and intercooler efficiency
23rd Dec, 2007 at 02:05:21pm
OK, I agree.
23rd Dec, 2007 at 02:23:05pm
I also found this, which is a quite an interesting read, looks like there is more to it than just increasing the compression ratio.
23rd Dec, 2007 at 02:54:15pm
23rd Dec, 2007 at 03:01:51pm
If you want to limit the torque output to say 100 ftlbs then you will only want to run 6-7 psi boost, in which case you maybe OK.
Edited by Paul S on 23rd Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Dec, 2007 at 03:01:59pm
I may not have this right but if an intercooler has the efficiencey of 80%, that means it can drop charge temps to within 20% of ambient air temp right? Where does that leave chargecoolers efficiency wise? Could they be really usefull if space isn't too tight? On 7th Nov, 2008 Nic said:
23rd Dec, 2007 at 03:05:14pm
On 23rd of Dec, 2007 at 03:01pm Jay#2 said:
I may not have this right but if an intercooler has the efficiencey of 80%, that means it can drop charge temps to within 20% of ambient air temp right? Where does that leave chargecoolers efficiency wise? Could they be really usefull if space isn't too tight? Yes, so as an example if the ambient is 20 degrees and the intercoler inlet temp is 120 degrees, then at 80% efficiency the oulet temp would be 40 degrees. Anything that helps reduce the intake temp would be useful. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Dec, 2007 at 03:07:16pm
Edited by Bat on 23rd Dec, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
23rd Dec, 2007 at 03:24:22pm
On 23rd of Dec, 2007 at 03:07pm Bat said:
Jay ... Depends on the efficiency of the charge cooler TBH I guess any cooler is only as efficient as the volume and temp of the medium that flows through it. I just thought with chargecoolers you had the ability of dropping below ambient air temps so hence could be over 100% efficient. Edited by Jay#2 on 23rd Dec, 2007. On 7th Nov, 2008 Nic said:
23rd Dec, 2007 at 03:32:11pm
23rd Dec, 2007 at 04:02:49pm
Refrigeration is all about latent heat.
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
23rd Dec, 2007 at 05:20:13pm
Very interesting thought Paul
23rd Dec, 2007 at 05:41:20pm
Edited by BENROSS on 23rd Dec, 2007.
23rd Dec, 2007 at 05:51:09pm
23rd Dec, 2007 at 06:10:49pm
On 23rd of Dec, 2007 at 05:41pm BENROSS said:
![]() With respect, we have seen those graphs before and whilst they are a useful guide, they are inconsitent and need clarification. The first one would suggest that 10 psi is Ok at 10:1. What octane rating is that at? What ambient temperature? What camshaft? The second one would suggest maximum of 6 psi at 10:1. What intercooler efficiency? What compressor efficiency? Are they UK or US type octane ratings? etc. I'm trying to refine the knowledge, based on science, rather than rely on generalisations. Hopefully we can back this up with practical tests. If you don't look outside the box, you do not know what is there. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Dec, 2007 at 06:16:31pm
Are those graphs for static or dynamic CR
23rd Dec, 2007 at 06:20:48pm
I'm sure that it is intended for static compression and will have been drawn with a large safety margin. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Dec, 2007 at 06:31:14pm
23rd Dec, 2007 at 08:33:32pm
I think TD clarified before that those graphs are for US octane ratings. On 7th Nov, 2008 Nic said:
23rd Dec, 2007 at 08:52:06pm
yes that’s true jay, here in the uk you can add 3 points to that
23rd Dec, 2007 at 08:57:52pm
