Home > Technical Chat > UNIPART OIL FILTER..GFE 1 superseeded by named Premuim
or know as the premium oil filter later on
i bought the last one from minispares north
unipart does not make them any more *frown*
this filter is "unique" as it has a 2 pence size magnetic trap installed and it filter the lot out
Anyone know where there is a nest of them ???
or may be we can togeather and ask unipart to re issue them ????
i have cut the filter open many years ago and they certainly do there job in the A series ...loads of ferrous silt which would have passed straight through the filter medium
anyone ?
They were standard on MPis. Didn't realise they'd stop making them :(
I wonder if Fram or someone do an equivalent?
there must be a motor factors out there some where with these....
i bought the last two from somerfords as well and this was right back september time
i have one left on the shelf
martpaul
Member #: 668
newton aycliffe (near durham)
theres a few motorfactors round here that have unipart parts galore so i can have a phone around for you!
martpaul
Member #: 668
have you got a part no.?
If needs be i can drop them off when I go to castleford.
GFE 21 or known as the premuim filter
I know they stopped making them around 18 months ago... I bought the last four from my supplier, and have one left.
I'm thinking we need to source a decent OEM filter from another supplier. Call me what you want, but i don't trust 'bling' aftermarket oil filters like Fram. You can't go wrong with a OEM part from a major manufacturer. Only problem is most modern filters have a by-pass built in. I'm still looking for one that doesn't.
Monster22
Member #: 39
http://www.minisport.com/acatalog/info_MAGMF001.html
What about one of these?
Sir Yun
Member #: 1592
Smart Guy!
You could rip the magnets out of a few old hard disks ( do you really need A 500 mb UNIT) or a few busted audio tweeters ( neodym type) and add them to any type of filter.
o if you want something store bought:
http://www.oneeyeindustries.com/domestic.asp
or http://www.filtermag.com/
Edited by Sir Yun on 22nd Jan, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Silly as it sounds...will any magnet stuck to the oil filter do the job?
On 19th Jan, 2010 wil_h said:
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Ive seen ones that wrap round the filter on the outside but they dont look convincing.
drop one in from the top and another on the bottom maybe??
TD ... Fram were factory fit from Cosworth *wink*
Sir Yun
Member #: 1592
Smart Guy!
you need a powerfull magnet hence i mentioned the neodym type..there suckers have ACME (think roadrunner.. meep meep) like qualities. bigger ones are downright hazardous.
a small one can pull as much a 6 kg.. if you take a few like the filtermag that will work.
just using a bit of araldite to paste a few smaller ones on a filter is a lot cheaper
TBH most of the filters are made in exactly the same factory, by the exactly the same machines and materials. Im sure its just a case of your paying for the name! *wink*
Fram might have been factory fit for cosworth, but that just means that that paerticular filter met cosworths needs. Way i see it, if you can buy a basic, premium, and premium plus filter from the same manufacturer, something is wrong. They should all be made to the same high standard as regards filtration capability.
Alex1340
Member #: 111
Loughborough
the "trying to remmber brand name" metro turbo oil filter that halfords sell but not the halfords brand the other one they carry has a magnet in the bottom of the filter.
black box. can't for the life of me remmber the make.......
champion i think
http://cgi.ebay.co.uk/MINI-TWIN-POINT-INJE...1QQcmdZViewItem
Any good?
Just found this
http://cgi.ebay.co.uk/MAGNOM-OIL-FILTER-MA...1QQcmdZViewItem
Could it be the answer?
tomkidd
Member #: 1962
Lancaster
I use this VW one on my mini, I was informed by the VW dealer that this has magnets as standard. Its slightly taller than the original mini one, but has the same thread
Edited by tomkidd on 19th Jun, 2008.
What vee dub's that off?
miniboo
Member #: 2253
Las Vegas, Brit in the States
At the last oil change I used a FRAM orange one cant remember the part number but i will chop it up and see whats inside if ya want??
thought this was interesting, not sure how 30 microns compare to the normalfilters though?
http://cgi.ebay.co.uk/Inspection-oil-filte...34.c0.m14.l1262
