Home > Help Needed / General Tech Chat > It's Dead - Autopsy 080308
I've managed to break something and now it will not run.
I went out yesterday in the car to do the latest datalog of the siamesed code, which is showing some promise.
The LC-1 Wideband on the outers was playing up and was stuck at 20:1, which I could tell was not right because it was running well and a few minutes earlier had been reading correctly. So I returned home.
I checked the programming on the LC-1, which appeared OK, so decided to do a quick re-calibration.
To get all the fuel out, I tried Evo's trick and revved it hard to say 5000rpm and switched off, the idea being to pump all fuel and exhaust gas out the system.
Since then, I've not been able to get it to start.
I have fuel in the tank, 3 bar fuel pressure on cranking and the plugs are getting wet.
I have a spark at the plugs, not blue but big fat orange type.
The Megasquirt is behaving. It knows when I'm cranking and is doing everything it should. I saved a log of severals starting attempts. The engine only cranks at about 150 rpm.
But, Ive only got 8.5 volts at the starter. So I changed the battery - no better. Changed the starter - no better. The volt drop from body to block during cranking is 0.7 volts.
I can get 50 psi oil pressure with the plugs out.
The engine temperature is only 2 degrees C so it is tight, but this first ocurred when the engine was quite warm, so I do not think it is that.
It is as if something is taking a lot of amps to turn and it is dragging the volts down, but god knows what.
Any ideas?
Edited by Paul S on 8th Mar, 2008.
paul i dont thing anythings gone pearshaped internally
one! thing you have soaked the plugs buddy
warm them up on the gas ring and dry them out, refitt and try again
it will spark at the plugs then
sound nuts but give it a go
Thanks Steve,
I've just tried that and still no go. I think a new set of plugs would be a good idea, these have done a few thousand miles.
Still refuses to spin over fast enough to start.
I checked the battery earth lead, 0.1v at cranking so it's not that.
I was hoping to sort this today as I'm off on holiday in the morning and I shall be whittling over it until I get back.
Any ideas?
This happened to me with the Vems, an which is why, unfortunately for me, I have to replace the board.
I always thought that if the spark was strong its was a big fat blue spark, and when its weak its orange???
Cold start enrichments could be out and with a weak spark and cold weather it will never fire, I also had this, and it took me ages to work it out
Low volts on cranking will cause a week spark.
The cranking enrichment works on a percentage of the normal calculated pulse width. At 0 derees C it is set at around 300 percent, so that's 3 times normal. but at 20 degrees it is set at 250%. I would not have expected it to make much difference.
However, I wonder if it firing all four injectors on cranking? Two are staged out at the moment. Then there will be 6 times the normal fueling. I'll go and check.
EDIT: Disconected the two injectors that are normally staged out. Nothing but a spectacular back-fire.
Also, coil resistance is normal 0.5 Ohms so I don't thing it the coils.
Edited by Paul S on 17th Feb, 2008.
Any ideas?
I read somewhere that sometimes widebands will output a high value when something is wrong.
Although the gauge showed 20:1, the datalog reading, which is taken from the LC-1 via a serial link was in the region of 45-50:1, which makes me suspect that it was outputing 12 volts. This could have damaged something in the ECU, but it does appear to be operating fine. I've had the board out the case and there is no evidence of a fault.
Have you got these settings right.
You have two settings, crank PW at -40c and crank PW at 77c this is the scaling. the -40 setting is usualy 3 times that of the 77 setting.
There is then the afterstart setting which is a percentage added, this is the scaled over time
If you are saying that you are 300% of the warm PW at 0c then you are overfueling. Problems start wen you are roughly 1ms away from the ideal
The MS2/extra code has a table rather than a linear setting, but I think that you are right.
The default setting is a bit high.
Cranking values:
326% at -12
301% at -1
276% at 10
251% at 21
Afterstart Enrichment does not come in until it is running and then it starts at 45% and quickly drops.
Warm Up Enrichment also comes in once it is running.
Scruffy
Member #: 328
Seaford Rise, South Australia
Don't know about Megajolt/squirt but anything under 11 volts with management -you can forget it! It is as simple as that with DTA or Omex - you check everything and all it is is good old volts!
On 5th Sep, 2011 Vegard said:
I think you are right.
I'm only getting 8.5v at the starter and just over 9 at the MS.
Scruffy
Member #: 328
I'm only getting 8.5v at the starter and just over 9 at the MS.[/quote]
Yes I would put money on it!
Paul ... I'd suspect the battery cable front to rear, or a poor connection at either end if the earths are good.
Cable from starter to solenoid is favourite if you've got an inertia setup.
0.7V seems a little high though, I'd put 0.5 as a maximum, with 0.25V being ideal...
the actual ecu should functin on 9v but the injectiors and coil may not cut it at this voltage,
jump leads directly to the solenoid and block??
Just tried it again, but no luck.
However, it did seem to be turning over faster.
The new battery has sit on the garage floor since I bought it a few months ago. I guess it needs a long charge before it is up to scratch.
I'll put it on charge on Friday night when we get back from Paris, then try again Staurday.
I have a wire from the battery running to my ECU just to power it - always had a problem with voltage drop knocking out the ECU unless it was a good battery (if i pulled the ECU feed from the end og the main battery wire in the engine room)...
Same with fuel pump - I have this wired straight to the battery - via a relay in the boot to minimise voltge drop.
Edited by turbodave16v on 17th Feb, 2008.
Actually, the ECU is holding up fine.
I've got a datalog from trying to start it and it has religiously saved the data every 1/4 second.
My money is on a combination of the cold temperatures, poor battery and over fueling.
Another possibility is that the engine is partially siezed.
If it does not start next weekend, then the engine is coming out to make way for the 998 turbo which I shall run NA until the tests are complete.
Surely this proves that the ECU is getting power & working?
What have you got the timing set to when cranking?
Perhaps it's just sulking after you circumcised it.
Yes, but the injectors and coil are not getting enough voltage.
It worked fine for a couple of laps round the village after the circumcision.
Maybe multiple starts on a poor battery and then no more.
Is the VR signal strong enough. with the low voltages the engine obviously turns over slowly, but is the rpm gauge registering. I suffered this too, and put it down to the battery that was 'designed' for the mini being too small and also the fact I abused it over the last year, even after a full day charge, it died. Went out and bought one of those super 500 amp jobs that fill the whole battery box, never had a problem since, well, not that one anyway, lol.
The rpm is registering in Megatune. It looks about right.
I've got two batteries on it now and it still will not start.
It's a good ten degrees warmer than last weekend, so I cannot blame the cold.
I've tried the following:
fitted new plugs
reflashed the code to the ECU
downloaded the setup again
tried previous setups
disconnected the widebands (heaters) to raise the voltage
The spark still does not as good as it should. It wanders around the plug rather than sits in the gap. So the next thing to do is try another coil pack.
My motivation is starting to wain.
Have you done a compression test to rule out anything dastardly internally
Have you checked the ECU grounds?
Obviously the ECU switches coils and injs to ground so this could be your problem, may also be the cause of the WBO2 failure?
That will have to be the next thing after the coil pack.
I think that they are OK. I checked out all the electrics this afternoon and could not find anything wrong except some slightly melted plastic fuse cases, which I replaced.
The ECU is ground to the servo bracket and the wideband grounds are firmly bolted to the engine.
should they not ground to the same point?
