Home > Technical Chat > Ceramic Turbine Wheels
El Potter
Member #: 2169
Malta (Ex. Scotland)
Is it true that having a ceramic turbine wheel limits you to about 15 psi boost?
Thanks
Tom
Warning:Stig in Training
If its on a Skyline, apparently it does... I guess this is stated for a reason.
El Potter
Member #: 2169
Well I don't own a Skyline,unfortunately, so does it still apply to Le Mini?
Has anyone bothered with a ceramic wheel on a mini yet??
making a wild assumtion here.... I have been lead to belive that ceramic wheels fail as they are brittle, given that a skyline turbo is going to be pretty big if the turbine was scaled down to a useful size for a mini it would be cosiderabley stronger, (like a small pane of glass verses a big pane of glass) so it should live to higher pressures.
are ceramic wheels avvailable in smaller sizes?
El Potter
Member #: 2169
Well the T3 I got has a ceramic wheel,or so I was told.
I only know cos I tried to sell it to a guy for his diesel and he opened it up and said it was a no go. Apparently diesels and ceramic wheels don't mix.
Never heard of a T-series with ceramic wheels ????
Ceramic wheels are good in theory. Unfortunately spin em too fast, and they fall apart.
Skylines, Toyotas, they all the same. Fragile as anything.
El Potter
Member #: 2169
Well I'm no expert Steve.
Just repeating what someone told me.
How can I recognize a ceramic wheel?
Hui,
Magnet won't stick to it?
And they break really easy lol....although breaking it is a poor test
tommyb
Member #: 934
halifax, west yorks
i'm pretty sure a magnet won't stick to most turbine wheels steel or ceramic. el potter do you know what the turbo is from or have you got the part number to check?
Edited by tommyb on 21st Feb, 2008.
turbo hogster
Member #: 178
stowmaket suffolk
ceramic bearings would be a better bet i think.
alot less drag so a bigger blower trim could be used, but they are damn expensive.
lol.....
Ceramic ball bearings and a caramic turbine wheel are 2 different things, but trying to achieve the same goals ( freer spinning wheels )
El Potter
Member #: 2169
Good idea Bat.
Tommy why won't a magnet stick to a steel wheel? BTW nice name*happy*
It came off my Metro Turbo engine.This is what's written on the TIN(Turbo Identification Number*tongue*) plate.
Cust P/N-CAM6924
ATD P/N-466146-1
S/NRCO-160A
Model No. TB0329
Thanks.
Tom
like this (from a std metro)....
does the turbine also look like this (also from a std metro)?
the build up of carbon can look like ceramic.
Edited by Joe C on 22nd Feb, 2008.
Hey, I had one of those over a decade ago....
Ceramic turbine wheel my arse.
tommyb
Member #: 934
halifax, west yorks
they are made of a non metalic material so it won't stick, also ceramic turbines don't have a nut on the end as its friction welded to the shaft instead.
El Potter
Member #: 2169
This is the turbine wheel in question.
Steel or Ceramic?
that looks like my one of my std metro t3s to me...
not ceramic.
El Potter
Member #: 2169
Good.
Thanks 13.
case closed gents.
tommyb
Member #: 934
halifax, west yorks
heres pic of a garrett ceramic turbine from a skyline for comparison you can see the 12 point 'nut' which isn't a nut and is actually part of the wheel itself
That is a usefull reference... Cheers!
Well, there's never really a nut on the turbine wheel is it?
