Home > Beginners Tech > standar turbo boost?
welshdan
Member #: 1111
s wales
if removing the ecu from a metro turbo engine, what boost can be run safely? im looking at avonbar actuators, and thinking that 8psi one would be suitable? many thanks
12H
Member #: 2156
wigan jnt 23 m6
id say that would be ok as the standard boost 7 psi
I take it this engine will be intercooled?
I will be looking to run 8-9psi on 9.4:1 comp ratio with intercooler
iirc its 4psi in the first two gears and 7psi in 3rd and 4th??? i have also heard some only run 4psi not sure about that though
Wrong, its 7psi up to about 3500rpm, 4psi from 3500 to 5k ish, then 7psi again after that. Done to cut out the big torque peak in the mid range so that the gearboxes did self destruct in warranty period.
metroturbo
Member #: 989
North Yorkshire
Not quite. It is 4psi up until about 4500rpm, then it increases in line with the revs until it maxes out at 7psi at about 6300rpm. Without the boost modulator system it is 4psi maximum.
Well whatever, its a crap band aid system that is best thrown in the bin.......
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Disconnected mine on my first turbo. :)
On 19th Jan, 2010 wil_h said:
redwing
Member #: 1574
Malta
The first job on my build was to flog the ECU on Ebay!!
toms right on this one
metroturbo
Member #: 989
North Yorkshire
The Austin-Rover repair manual, Vizard's guide, and the boost gauge in my standard Metro Turbo all match what I stated.
mg-metro-matt
Member #: 1870
Aldershot (we are top of the league, say we are...)
mine is as metro turbo states, 4psi upto about 4000rpm then it gradually increases to about 7psi near the red line
welshdan
Member #: 1111
s wales
and what is the best option to replace the ecu with?i will want to run about 7 psi of boost. im familiar with na builds, turbos are new teritory to me. many thanks
Replace with a bleed valve.
Quickest and easiest way.
You could fit a bleed valve, a strong actuator or put more pre load on the exsisting acuator. Which ever you do measure the boost pressure with a guage and get the fuelling checked on a RR :)
welshdan
Member #: 1111
s wales
do bleed valves come pre set,eg, only allow 7psi boost? also is there a guide on here to fitting one? where is the best place to get one?many thanks
just fit it fully open, so its letting all the pessure through to the actuator (i.e. not bleeding off any pressure), then gradually increase the amount bled off bit by bit till you have the desired boost level.
Whilst using a boost gauge!!!!
welshdan
Member #: 1111
s wales
so if i fit a '7psi' actuator and a bleed valve it will be limited to 7psi when on boost?
Turbo Tel
Member #: 588
Delaware, USA
Fit a 7psi actuator OR a bleed valve.
A bleed valve bleeds off some of the pressure so that a 4psi actuator only "actuates" when 7 psi is available, 4psi goes to the actuator and 3psi is bled off to the atmosphere.
If you have a 7psi actuator you dont need a bleed valve..
Edited by Turbo Tel on 23rd Mar, 2008.
welshdan
Member #: 1111
s wales
so a 7psi actuator, the engine will run on boost all of the time, at 7psi?
Turbo Tel
Member #: 588
Delaware, USA
Yes
welshdan
Member #: 1111
s wales
great. so what if i fitted a standard metro turbo actuator? are these set at 4 or 7? many thanks
Turbo Tel
Member #: 588
Delaware, USA
I believe they are 4psi
welshdan
Member #: 1111
s wales
cheers.thanks for your help. any idea what cars were fitted with 7psi ones, what is compatable etc? someone said montego (i think) turbo, will have a hard time finding one of those though.
