| Home > Help Needed / General Tech Chat > light flywheel on my engine? | |||||||
1st Apr, 2008 at 05:16:20pm
hi, can anyone advise if an ultralight flywheel would be benificial to my build?
1st Apr, 2008 at 05:20:33pm
also going to run rs turbo intercooler, and a 13 row oil cooler.ta |
1st Apr, 2008 at 05:46:26pm
Yes, get the ultralight, and go for a grey spring, bit overkill for 6/7 psi, but you will not stay that low in future.
1st Apr, 2008 at 06:15:07pm
cheers.how about the head?would it be worthwhile having the unleaded seats put in and porting and polishing it?thanks |
1st Apr, 2008 at 08:36:12pm
the head makes a BIG! diffrence with race valves etc......... unleaded stops you from adding lead replacement additives thats all
1st Apr, 2008 at 11:10:30pm
obviously the pistons and head are standard spec, so putting it together as it is. build is costing a fortune so will uprate pistons/head in future.
1st Apr, 2008 at 11:19:12pm
minispares north get flwheel and back plate and AP race plate
1st Apr, 2008 at 11:21:56pm
seen a few on ebay.any good or stay clear? |
1st Apr, 2008 at 11:39:20pm
dont know ?
2nd Apr, 2008 at 12:05:28am
2nd Apr, 2008 at 12:05:55am
2nd Apr, 2008 at 12:27:06am
so with an ultralight flywheel i will defineately feel a difference in response and performance? |
![]() 189 Posts Member #: 1774 Advanced Member Sydney AUS |
2nd Apr, 2008 at 03:12:31am
Hi Dan,
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
2nd Apr, 2008 at 11:52:49am
i will be porting and polishing the head. if you lighten the flywheel dand have them ballenecd together?
2nd Apr, 2008 at 11:54:14am
sorry, lost a bit of the last post. - if you ligen the flywheel do you have to remove the crank and have them balenced together? |
2nd Apr, 2008 at 12:04:51pm
Balancing the lot is the best way to go... take them all in and balance 1132cc Turbo ~120 bananas ATW - Fun Fun Fun
2nd Apr, 2008 at 12:22:49pm
Pete (pristic), slightly off topic, but I see you are using the Hypatec pistons...
2nd Apr, 2008 at 12:27:06pm
10psi on standard components is fine with an intercooler.
In the 13's at last!.. Just |
2nd Apr, 2008 at 11:40:27pm
i have a sccr gearbox with sc drops, and 4 pin diff.all tran x.ta |
2nd Apr, 2008 at 11:48:54pm
dan, 11 stud drilling dan 12.5 mm water pump side into the block and no! more.
2nd Apr, 2008 at 11:49:35pm
the engine is standard cr. im not worried about the quality of the standard parts, but what they can withstand at standard cr.
2nd Apr, 2008 at 11:52:17pm
benross, do you mean the crowns are thick for machining deeper dish for more cr? how about other a+ pistons? i have an allegro engine, and a few 1275 mayfair ones. |
2nd Apr, 2008 at 11:55:56pm
use the standard ones on your spec if you are on a budget rockers Edited by BENROSS on 3rd Apr, 2008.
3rd Apr, 2008 at 12:08:35am
as i said im not looking for a moded head at the moment. i realise this is the way to go but cannot justify spending any more money at the moment. i will be happy with 100bhp, maybe a little more from my 1st turbo engine.
3rd Apr, 2008 at 12:16:31am
yes the bushes will work ok with the SW5 cam, but...... in genrall!!! i would not bother in a force induction engine its not worth the effot ... some may disagree
