| Home > Technical Chat > help new engine smoking | |||||||
29 Posts Member #: 2022 Member caerphilly |
13th Apr, 2008 at 09:25:41pm
hi chaps, im preety sure its the valve stem/guides, but heres the low down.
13th Apr, 2008 at 09:28:47pm
MSPD is morspeed.
13th Apr, 2008 at 10:07:37pm
more speed eh, their quite good arnt they?, i spose the breathers could do with a wash, didnt think they were that bad to be honest. i was givin a rich needle with the bits i had that i put in but took out today, the one in there now says bdd, thats the standard one right?.i got it nice and warm and turned it down to its minimum as i thought the same thing, it doesnt pink or splutter etc. The car goes like hell and was pushing a clio 182 earlier. the lip on my exhaust is oil its that bad. ill check the oil drain also
13th Apr, 2008 at 10:25:50pm
13th Apr, 2008 at 10:29:40pm
cheers gavin
13th Apr, 2008 at 10:30:52pm
cheers gavin
13th Apr, 2008 at 11:12:35pm
14th Apr, 2008 at 08:25:39pm
thanks for the reply guys, how long would excess oil in the exhaust take to burn off? i did the incline test again to reasure my self and it carried on smoking!! |
14th Apr, 2008 at 08:44:14pm
14th Apr, 2008 at 08:45:08pm
On 13th Apr, 2008 leetre said:
The car smokes at idle, also on over run, but when your going and boosting its fine. car is on 4 psi cheers lee Could it be the turbo seals if it doesn't smoke on boost? I'm no turbo expert. Edited by minimole23 on 14th Apr, 2008. On 7th Oct, 2010 5haneJ said:
14th Apr, 2008 at 09:00:48pm
just had a little play outside now, took spark plugs out and had a look at the pistons. 4 and 1 a bit cruddy but not wet, 2 is perfect and 3 has a pool of oil on the top, is this the stem seals, guides?? |
14th Apr, 2008 at 09:11:26pm
14th Apr, 2008 at 09:19:59pm
pheeww, thats a bit of a relief, i do hope it is these and not the rings. All i can say then chaps is morspeed do shit heads. This head is new and has only run a week.
14th Apr, 2008 at 09:50:15pm
14th Apr, 2008 at 10:12:09pm
you stated NEW T3 ??? was it new seconhand NEW ...... or new
14th Apr, 2008 at 10:14:20pm
no completly new, ill show you a pic |
14th Apr, 2008 at 11:09:47pm
14th Apr, 2008 at 11:58:27pm
i read this wrong Bat
15th Apr, 2008 at 09:26:11am
thanks guys, a mechanic told me to put deisel in the bores to check the rings, anyone tried this?? |
15th Apr, 2008 at 09:53:39am
If you phone up Morspeed and quote the head number, he'll be able to tell you all about it. i'e' when it was made and to what spec and for who. He relieves the exhaust guides slightly to stop binding (as he should do) so you need to run seals on the exhausts.
16th Apr, 2008 at 07:04:29am
also take of the little kn oil breathers as these can clog very easily causing crankcase pressure, always looking for them bigger bunches of bannanas |
16th Apr, 2008 at 11:31:33am
ok cheers guys, phoned more speed and were very helpfull, offering to have the head back to repair it, cant fault them
16th Apr, 2008 at 12:25:29pm
17th Apr, 2008 at 09:39:00pm
a little update, found the valve stem seals not where they should be, but floating on the valvs.
17th Apr, 2008 at 09:50:12pm
You need to make a tool to do it.
