| Home > Help Needed / General Tech Chat > Brain storming | |||||||
14th Sep, 2008 at 06:47:07pm
I have a problem I would like some brain storming on. I have my own thoughts but looking to see if there are any I have overlooked.
14th Sep, 2008 at 06:50:24pm
timing? |
14th Sep, 2008 at 06:56:48pm
as above....ignition timing
Edited by Jason G on 14th Sep, 2008. On 19th Jan, 2010 wil_h said:
14th Sep, 2008 at 06:59:47pm
wrong plugs? i know peugeots run crap on NGK but really well on bosh.
14th Sep, 2008 at 07:00:02pm
Forgot to add that the maps and start parameters are suposedly of and identical engine that has been mapped and running
14th Sep, 2008 at 07:02:59pm
These are NGK plugs and are the same ones in several other similar engines.
14th Sep, 2008 at 07:06:36pm
do you know that there is definately feul getting into 1 and 2?
14th Sep, 2008 at 07:06:46pm
erm doesent the k head on the a series block end up with a different firing order?
14th Sep, 2008 at 07:07:57pm
duff coil,??? |
14th Sep, 2008 at 07:09:02pm
I would look at the coil.
14th Sep, 2008 at 07:14:15pm
Firing order is 1243. Normal firing order is 1342, so as you can see on wasted spark, and batch fire, it wont make any difference about the different firing order On 26th Oct, 2004 TurboDave16v said:
14th Sep, 2008 at 07:19:28pm
Yes, things to check, swap injectors round, a swap plugs around, swap leads around, and change out coil pack for a known good one. All one at a time On 26th Oct, 2004 TurboDave16v said:
14th Sep, 2008 at 07:31:18pm
is this with tb's or a plenum?
14th Sep, 2008 at 07:34:43pm
TB's
14th Sep, 2008 at 09:01:23pm
have you checked compressions, could valves not ne seating fully, have you shimmed up correctly,? |
14th Sep, 2008 at 10:16:07pm
14th Sep, 2008 at 11:27:08pm
Not my engine, but its one thing on the list to check :) On 26th Oct, 2004 TurboDave16v said:
15th Sep, 2008 at 07:42:51am
I think I'm probably saying the same as Paul but for a different reason but try swapping the leads 1 to 4 and 2 to 3.
15th Sep, 2008 at 09:20:42am
That was my thinking Rod.
15th Sep, 2008 at 09:37:35am
Stuff a Dizzy in it lol
15th Sep, 2008 at 09:37:49am
Isn't this the same sort of problem that Joe had?
In the 13's at last!.. Just |
15th Sep, 2008 at 10:21:12am
When was the last time TM was PC.
15th Sep, 2008 at 10:35:45am
On 15th Sep, 2008 Sprocket said:
When was the last time TM was PC. Its the first I heard about 'brain storming' being PC. I have never heard anything so daft ![]() I agree, it's ridiculous! and after checking google, it seems that even the epileptics aren't bothered about it. In the 13's at last!.. Just |
15th Sep, 2008 at 11:01:08am
This is a typical Example of valve seat not sealing, Do a Compression test all will be reviled On 17th Feb, 2009 Rob H said:
15th Sep, 2008 at 07:23:15pm
crank has snapped, only 2 pistons are moving.
