| Home > General Chat > Dumpvalves | |||||||
194 Posts Member #: 2873 Advanced Member Milton Keynes |
29th Sep, 2008 at 11:52:09pm
Wat dumpvalve do u guys think is best overall? |
30th Sep, 2008 at 07:46:17am
Depends what you define as 'best'.
30th Sep, 2008 at 12:49:52pm
the only thing they do is sound nice if that's what you like, other then that they do nothing we don't have big enough turbos to worry about getting the pressure out when we lift off. if you run a T4 then you do need one to help the turbos life. Best 1/4 mile 13.2 seconds @116 mph
30th Sep, 2008 at 01:00:10pm
I wouldn't run any modern type turbos (Gt seires for example) without one TBH!! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 6753 Posts Member #: 828 Post Whore uranus |
30th Sep, 2008 at 01:08:23pm
what he said ^^^^^^^
30th Sep, 2008 at 01:08:39pm
Mine was definatly making that chirping surge sound when lifting off at 1 bar, sounds like the 6 million dolar man sound when he jumps over stuff.
30th Sep, 2008 at 01:32:15pm
The seals on the piston types can swell with fuel contamination (the Bailey type for example) causing the piston to stick open and the diaphram types can split. Did anyone ever find a supplyer of the kevlar or whatever diaphrams? On 7th Nov, 2008 Nic said:
30th Sep, 2008 at 01:36:16pm
Im sure Ric managed to get hold of a kevlar diaphragm. Can't remember where from but its on another thread somewhere quite recent. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Sep, 2008 at 03:19:34pm
i use a grpA forge one that seems to have been reliable. |
30th Sep, 2008 at 06:11:39pm
demon tweeeks?
30th Sep, 2008 at 07:59:06pm
I got rid of the dump valve as it irritated me no end hissing and farting every time I lifted off.I now get a loud chirrup every time,nearly as annoying,and I,m only on 8 psi at the moment.Makes the car sound like the rally cars entering a fast corner when I,m still inside the 30 limit. |
30th Sep, 2008 at 08:10:15pm
I dont run a dump valve they do my head in! |
30th Sep, 2008 at 08:29:23pm
Id much rather have the chirrup than the wooooooooooooooooooooooooooooooooooooooooooooooootaaaaaaaaaaaaaaaaaaaaaaaaaaaassssssssssssssssssssssssssshhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.................
30th Sep, 2008 at 09:01:37pm
Hmmm, so which causes more problems diaphram or piston? and which have a better sound? |
136 Posts Member #: 1751 Advanced Member chichester/bognor |
30th Sep, 2008 at 09:47:21pm
piston i think is better if kept serviced.had one on 200sx.and the chirrup sounds awesome like that alot more.and run that for a while at 15 psi no probsfor ages chekced turbo after ten odd thousand miles and was fine
On 30th Aug, 2008 Richie said:
too much my wife says "not that friggin site again" so i pull my pants back up and turn it over to TM. iam on pretty much every day as i lead a sad existance |
30th Sep, 2008 at 10:00:19pm
I think the fuel contamination is down to being carb fed rather than fuel injected. Some people mount the DV upside down with a 45 degree hose off the plenum and this might help? Don't know, mines on the shelf along with all the other bits. On 7th Nov, 2008 Nic said:
30th Sep, 2008 at 10:06:44pm
i ran with a HKS SSQV on my supra, tune-able sound and you can keep the compressor surge at low rpm if ya want (the rally car sound) i got bores and removed the insert..to give a quiet wooshh
Yes i moved to the darkside |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
30th Sep, 2008 at 10:16:10pm
On 30th Sep, 2008 Jay#2 said:
I think the fuel contamination is down to being carb fed rather than fuel injected. Some people mount the DV upside down with a 45 degree hose off the plenum and this might help? Don't know, mines on the shelf along with all the other bits. Yep, it's fuel vapour which swells the seal on the piston ones causing them to stick, you can get a Viton seal to stop this, or have it upside down as suggested above. |
30th Sep, 2008 at 10:17:04pm
On 30th Sep, 2008 Brett said:
i ran with a HKS SSQV on my supra, tune-able sound and you can keep the compressor surge at low rpm if ya want (the rally car sound) i got bores and removed the insert..to give a quiet wooshh imo the ssqv is the best will not leak at any boost level eitherI've never seen these used on mini's i always thought they weren't possible to use! |
30th Sep, 2008 at 10:17:35pm
30th Sep, 2008 at 10:21:06pm
i ran with a HKS SSQV on my supra, tune-able sound and you can keep the compressor surge at low rpm if ya want (the rally car sound) i got bores and removed the insert..to give a quiet wooshh imo the ssqv is the best will not leak at any boost level eitherI've never seen these used on mini's i always thought they weren't possible to use! you can run them on anything with a turbo aslong as you can plumb it up, if it could dump 1 bar of boost at 7000rpm on a 3 litre engine, a mini will be no problem
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
30th Sep, 2008 at 10:21:24pm
The dump valve as most of you know is fitted to relieve the pressure build up seen at the output of the compressor. If this pressure is aloud to build without release it will cause the compressor to slow down and any increase in pressure will cause an increase in temperature. So here the dump valve helps prevent the rotating assembly from stalling.
Own the day
30th Sep, 2008 at 11:57:39pm
1st Oct, 2008 at 07:29:57am
i had a diaphram DV for some time and never had a problem with it till the diaphram slit. i then got a piston one and it got stuck all the time, standard grease would last the day, copper grease would last about 2 days and silicone grease would last over a week. after the seal failed i fitted some cheap o ring from the car spares shop but fitted the DV with the vac pipe pointing to the ground. never had a problem since and that was about 3 years ago |
499 Posts Member #: 2257 Senior Member Brighton |
2nd Oct, 2008 at 12:43:58am
Ran a Blitz SSDV on my Impreza, never had a problem with it and pretty tempted to get one again for my mini! |
