| Home > Help Needed / General Tech Chat > Maniflow downpipe and large bore systems. | |||||||
30th Oct, 2008 at 09:24:10am
I have a maniflow 2" OD turbo downpipe to fit to my t3 elbow.
30th Oct, 2008 at 09:54:27am
First, are you sure the 3" doesn't just refer to the size of the tailpipe ???
30th Oct, 2008 at 10:10:13am
Not at all Rod thats what I wanted to hear!
30th Oct, 2008 at 10:22:19am
On 30th Oct, 2008 richminiturbo. said:
So i'm guessing the front pipe in 2" mild steel maniflow turbo system, is flared at the manifold end to fit over their 2" turbo downpipe. I've never seen one but that would be my guess also. I was quite surprised when my link pipe came unflared but was just told by the suppliers that the flare was on the "Y" piece as it's meant to go on an LCB, not a turbo downpipe. It seems maniflow are the only people who make the complete turbo system and presumably they have chosen to put the flares the conventional way around at that join, maybe deliberately to stop people mixing other parts with theirs ??? Simplest solution would be a 2" bore sleeve that slides over both downpipe and linkpipe - if you stay with 2"..... I remember the Benross post but I thought he put the restriction down to a particular make of silencer ??? Schrödinger's cat - so which one am I ??? |
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
30th Oct, 2008 at 10:23:14am
Spent a lot of time and money on this myself and ill say this 2.5" straight through on a single box beats all other systems I have fitted. Designed this back in 94 spent months fitting systems to my car and this set up won by a mile! had to source the pipe and get it bent to my design though.
Own the day
30th Oct, 2008 at 10:33:31am
On 30th Oct, 2008 Rod S said:
I was quite surprised when my link pipe came unflared but was just told by the suppliers that the flare was on the "Y" piece as it's meant to go on an LCB, not a turbo downpipe. EDIT - thinking back, I think what they actually said was the "Y" piece of the LCB was slightly smaller than 2" at the join so the link pipe didn't need to be flared to fit over it..... Whichever way round it was, they were adamant the link pipe shouldn't be flared. Edited by Rod S on 30th Oct, 2008. Schrödinger's cat - so which one am I ??? |
30th Oct, 2008 at 01:17:23pm
Think I'll just opt for the maniflow 2" system, will save me hassle! |
30th Oct, 2008 at 01:20:30pm
On 30th Oct, 2008 richminiturbo. said: sensible decision. My system requires rebuild and the cost of fabrication is getting stupid.
Think I'll just opt for the maniflow 2" system, will save me hassle! Own the day
30th Oct, 2008 at 05:56:39pm
The Playmini Big bore exhaust is a 2" system with a 3" tailpipe. Well its not actualy a 3" tailpipe, but a 2.5" tail pipe with a rolled end that has a major diameter of 3" On 26th Oct, 2004 TurboDave16v said:
30th Oct, 2008 at 06:50:22pm
30th Oct, 2008 at 07:02:21pm
Cool thanks for that guys, think I'll order the maniflow turbo system and see how it goes, perhaps change the silencer later on!! |
30th Oct, 2008 at 11:54:57pm
i wasnt sure what happened with steve's maniflow back box, but i can see right through mine, so def no restrictions in there...? "Turbo's make torque, and torque makes fun"
31st Oct, 2008 at 12:24:36am
rich, use the maniflow 2" down pipe system buddy and the pipe right up to the back box.. this is good for powe outputs around 225 bhp with out ristriction.
31st Oct, 2008 at 07:54:03am
Oki doki thanks for the info Steve!
31st Oct, 2008 at 12:02:39pm
The Playmini 2" link pipe is 2", its not swaged. I thought the turbo downpipe was 2" Swaged? so the link pipe would slip into the down pipe? On 26th Oct, 2004 TurboDave16v said:
31st Oct, 2008 at 06:19:30pm
correct sprocket
31st Oct, 2008 at 06:23:47pm
I was thinking of getting the maniflow front pipe. which obviously is swaged to go over their downpipe.
31st Oct, 2008 at 06:37:55pm
All ive done is use the standard t3 downpipe with the elbow jobby on, then put an enlarger on to increase the size from 2" to 2 3/4" used stainless pipe all way to the back and welded a rc40 tail pipe on the end to make it look nice.
31st Oct, 2008 at 06:45:46pm
u blatenly wnt a 4" syst on it! thts wot the scooby chavs use init!! |
31st Oct, 2008 at 06:51:18pm
31st Oct, 2008 at 07:27:58pm
Dust bins are all plastic around our way now.... Surely they would melt ???? Schrödinger's cat - so which one am I ??? |
31st Oct, 2008 at 08:09:37pm
On 31st Oct, 2008 Rod S said:
Dust bins are all plastic around our way now.... Surely they would melt ???? Nah, they are just for show, the real tail pipe is tucked under the rear valance and has a diameter of 1 1/4" On 26th Oct, 2004 TurboDave16v said:
1st Nov, 2008 at 12:24:16am
Edited by Bat on 1st Nov, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
1st Nov, 2008 at 12:44:26am
gav, red cross galore here mate "Turbo's make torque, and torque makes fun"
1st Nov, 2008 at 04:28:54pm
same here...
