| Home > Help Needed / General Tech Chat > Dot 5.1 brake fluid | |||||||
15th Jan, 2009 at 09:49:14pm
Regardless of the brand is the "must have" type for hi performance?
15th Jan, 2009 at 10:03:10pm
its boiling point is about 11 degrees Celcius higher than DOT4. which is around 180 degrees |
15th Jan, 2009 at 10:12:42pm
Someone mentioned about problems with synthetic based brake fluids on another post the other day. I've never really considered that until now. On 19th Jan, 2010 wil_h said:
15th Jan, 2009 at 10:13:37pm
Surely if you don't mix them you sould be fine? On 21st Jan, 2011 fastcarl said:
15th Jan, 2009 at 10:16:41pm
never even thought to look to be honest with brake fluid. I know engine oil you don't mix them. On 19th Jan, 2010 wil_h said:
15th Jan, 2009 at 10:22:24pm
Dot 3, 4 and 5.1 are all "generally" mixable as they are all glycol based.
15th Jan, 2009 at 10:25:46pm
AP Racing Dot 5.1 Brake Fluid
15th Jan, 2009 at 10:32:17pm
good info, cheers. Got to fit wheel cylinder on the van at some point.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
15th Jan, 2009 at 10:50:35pm
But the weird thing is the really good AP Racing PRF 660 fluid is only dot 4. Its got higher wet and dry boiling point. |
15th Jan, 2009 at 10:55:29pm
Yes, it is all a bit odd with this info...
15th Jan, 2009 at 11:01:09pm
bit o/t but i saw some rather sweet 2 piece bleed nipples at the motor show, with a 1 way valve in for single handed bleeding, got a pic somewhere... "Turbo's make torque, and torque makes fun"
15th Jan, 2009 at 11:06:54pm
15th Jan, 2009 at 11:07:07pm
What is brake fluid? Is it a type of oil or something? Not something people really talk about.
15th Jan, 2009 at 11:07:10pm
If its for your track car i'd get a good branded 5.1. Bleed your brakes often and i'd say you'd be fine.
15th Jan, 2009 at 11:11:14pm
Will do Mr Mirage, I generally change the fluid once a season unless something drastic happens.
15th Jan, 2009 at 11:19:34pm
How often do you bleed them? I'd do this a bit more often. Some circuit stuff gets bled up at least once a day. Real pain in the arse!! lol
Edited by Mirage on 15th Jan, 2009. |
15th Jan, 2009 at 11:23:20pm
No I bleed them pre race everytime, but change the fluid just once a year. Never had a brake problem except at Lyden Hill that is very hard on the brakes where I used a lesser quality Fluid.
15th Jan, 2009 at 11:30:18pm
sounds spot on prep to me fella.
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
5th Oct, 2009 at 11:33:37am
Guys.
5th Oct, 2009 at 12:11:24pm
Why would you want to use DOT5?
5th Oct, 2009 at 12:23:55pm
Another thing to consider - although modern seals are compatible with both silicone and glycol, they do absorb the fluid to a certain extent.
5th Oct, 2009 at 12:30:05pm
On 15th Jan, 2009 miniminor63 said:
its boiling point is about 11 degrees Celcius higher than DOT4. which is around 180 degrees True but DOT is a spec and it lists minimums not maximums... Castrol SRF is dot 4 for example and about the best money can buy.... Halfords racing stuff is very good value for money - failing that Motul RBF 600 is good. http://www.opieoils.co.uk/c-450-brake-fluid.aspx Alex AlexF |
5th Oct, 2009 at 01:39:09pm
On 5th Oct, 2009 Vegard said:
Why would you want to use DOT5? Buy some decent 5.1 at Halfords and you'll be off. The only reason was that I assumed 5.1 being made of the same stuff as dot 3 & 4 would eat the paint. On 5th Oct, 2009 Rod S said:
Another thing to consider - although modern seals are compatible with both silicone and glycol, they do absorb the fluid to a certain extent. Therefore it is good practice to replace all the seals if you are changing from one fluid type to the other. Otherwise the seals may degrade quicker than expected. Yeah I read that somewhere Rod. I have a new yellow band master cylinder from spares and all new brake lines so dot mixing isnt an issue. My main concern (after performance) was the paint eating. Does 5.1 not eat paint then? Ah cool cheers Alex, I think I go to halfrauds and have a gander. EDIT: Ok, found abit out for myself for a change! =) Dot 5.1 does eat paint. http://au.geocities.com/ozbrick850/brake-fluidtypes.html Edited by Ben. on 5th Oct, 2009.
5th Oct, 2009 at 02:30:10pm
5th Oct, 2009 at 03:26:36pm
5.0 is shite - simple as!
AlexF |
