| Home > Help Needed / General Tech Chat > charge cooler Vs intercooler | |||||||
38 Posts Member #: 5170 Member Bourne |
7th Feb, 2009 at 10:32:17pm
has anybody ever run a cahrgecooler instead of a intercooler. what would the advantages/disadvantages of running one of these?
My sister looks like me but with long hair! so save that one for your wank bank i dare you!... |
7th Feb, 2009 at 10:57:35pm
basically a charge cooler (water - air) is better at short periods of boost eg drag stip as it has the ability (fluid dependant) to get down to below ambient temps for a short period of time.
Edited by James_H on 7th Feb, 2009. |
7th Feb, 2009 at 11:29:13pm
An advantage of an intercooler is that it (generally) has no moving parts to fail. |
315 Posts Member #: 3013 Senior Member Epsom Surrey |
7th Feb, 2009 at 11:53:19pm
well intercooler will only cool to ambient temps where as a charge cooler will always go colder!! so if its a hot day at the drap stip u can run a nice cool charge compared to a intercooler!!
8th Feb, 2009 at 12:32:53am
how about both? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
8th Feb, 2009 at 12:57:00am
well both is overkill really!! just put some ice down your resivoir tank and itll be fine!!
8th Feb, 2009 at 08:57:28am
8th Feb, 2009 at 11:12:21am
yeah but excort cossie was crap because it ran the coolant from a hot engine through it rather than a separate tank of cold water |
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
8th Feb, 2009 at 11:32:20am
There is a chap with a red mini, miglia arches, 12" spectrums, at bristol mini day quite often, and was at combe. That was running a charge cooler, and it seemed to work quite well. But thats all i know. Sorry Chaps. On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
8th Feb, 2009 at 12:01:07pm
im planning a charge cooler, keep the ideas comming Yes i moved to the darkside |
8th Feb, 2009 at 12:06:40pm
go chargecooler !!! im planning on going charge cooler with mine eventually
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
8th Feb, 2009 at 12:55:14pm
wanna go charge cooler too, was thinking putting the charge cooler rad in the boot with a large header tank of say about to ltrs to keep heat soak at bay |
8th Feb, 2009 at 01:09:05pm
aslong as u can get air to the cooler rad youll be ok, just make some vents i supose!!
11th Feb, 2009 at 05:04:52pm
i use a chargecooler, no need for holes in the bonnet and its much easier to position than an intercooler |
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
11th Feb, 2009 at 07:19:55pm
On 8th Feb, 2009 DD_Racing said:
yeah but excort cossie was crap because it ran the coolant from a hot engine through it rather than a separate tank of cold water Really?? fuck me how crap, charge heater more like! 90 degree ACT's anyone? On 15th May, 2009 TurboDave said:
![]() 367 Posts Member #: 1643 Senior Member West London |
11th Feb, 2009 at 07:36:28pm
Lightweight racer coming soon. |
11th Feb, 2009 at 09:14:21pm
i was considering a escort cossie one on my mini but the length becamse a issue as its quite long!!
11th Feb, 2009 at 09:18:52pm
So tell me, how can a charge cooler lower temps below ambient (bar using dry ice etc)? On 7th Nov, 2008 Nic said:
11th Feb, 2009 at 09:28:49pm
On 11th Feb, 2009 Jay#2 said:
So tell me, how can a charge cooler lower temps below ambient (bar using dry ice etc)? the liquid in the charge cooler system can be cooled below ambient but the air cannot, ice would have to be used or ive seen charge coolers using CO2, a cryo cooler or some thing lol Edited by Brett on 11th Feb, 2009. Yes i moved to the darkside |
11th Feb, 2009 at 09:32:10pm
well say its a hot day u will always notice a lack of power compared to when youve got a nice cool day in a car thats running a intercooler where as if you have a charge cooler the water is below ambient temps regardless of how hot the day is...
11th Feb, 2009 at 09:49:48pm
On 11th Feb, 2009 DD_Racing said:
well say its a hot day u will always notice a lack of power compared to when youve got a nice cool day in a car thats running a intercooler where as if you have a charge cooler the water is below ambient temps regardless of how hot the day is... providing you run a good size radiator for the water to pass through and depending on the volume of water in the system because obviously its gona be like a kettle the more water you have the longer it takes to boil!! plus when your running around off boost pottering the water is contantly being cooled!! but the water is being cooled by ambient air at ambient temps?????? |
11th Feb, 2009 at 09:53:46pm
Cars on track will warm the water, simple.. its only good for short bursts IMO.
152 Posts Member #: 1074 Advanced Member Northamptonshire |
13th Feb, 2009 at 05:20:02pm
You can't generalise on how the system will perform. It depends on many factors such as the water pump flow and radiator size (to reject heat from the water)
Edited by matnrach on 13th Feb, 2009. |
3596 Posts Member #: 655 Post Whore Northern Ireland |
14th Feb, 2009 at 12:20:08am
well say its a hot day u will always notice a lack of power compared to when youve got a nice cool day in a car thats running a intercooler where as if you have a charge cooler the water is below ambient temps regardless of how hot the day is... providing you run a good size radiator for the water to pass through and depending on the volume of water in the system because obviously its gona be like a kettle the more water you have the longer it takes to boil!! plus when your running around off boost pottering the water is contantly being cooled!! but the water is being cooled by ambient air at ambient temps?????? There must be some rocket science to this, that we arent understanding...... Having owned and driven cars with both A2A, and A2W coolers.....I havent experienced what this guy explains above. 9.85 @ 145mph
14th Feb, 2009 at 12:24:28am
On 7th Feb, 2009 jwb_moto said:
has anybody ever run a cahrgecooler instead of a intercooler. what would the advantages/disadvantages of running one of these? e.g. http://cgi.ebay.co.uk/lotus-turbo-intercoo...A1%7C240%3A1318 or http://cgi.ebay.co.uk/WATER-AIR-POLISHED-A...A1%7C240%3A1318 Ive just built a load of these for our prototype tier 4 diesel engines, they run at such a high pressure that we have to have them made out of cast stainless steel weighing in at 145kilos as the alloy cast one just expanded and split even with a stainless ladder rack fitted between the two body halves. just exactly how much boost are you running ??? Ive seen Europes fastest drag truck, which runs compound turbos, and I assume a hell of a lot of boost. The Intercooler on it was absolutely huge, so I can only imagine the forces within it !! As for the A2W setups you pictured. Cant comment on the quality of those shown, but that style is very popular in the US for drag racers. 9.85 @ 145mph
