Home > General Chat > Gearbox baffle plates?
lockfast
Member #: 2775
Aberdeen
Is anyone using these thin plates that you can get to sit above the gearsets? If so what do you think of them? I can see advantages and disadvantages to them and just wandered what everyone else take on it was?
I can only see that your bores and camshaft might have there oil spray from the box stopped, there for it might make things wear out faster.
I fabricated my own (which I am considering testing the market) and have run it for several years with no problems. The engine shouldnt need spray from the gearbox as it was first designed to have a seperate gearbox anyway.
Ill get some pics up shortly
Paul
Paul do you have under crown cooling jets?
My only concern would be increased wear on the bores due to bore washing if you were running rich, obviously if you're fueling is correct this won't be an issue.
DD_Racing
Member #: 3013
Epsom Surrey
all the oil comming out of the big ends and mains gets flicked everywhere anyway so i shouldnt think the bores would suffer!!
Rob, I run n/a so no undercrown jets and yes my fuelling is spot on. Tbh I cant see that any oil would get past my crank to the bores anyway at 8000 rpm plus.
Heres my tray
Its made from 1mm NS4 (hard aluminium)
Paul
Edited by paul wiginton on 6th Sep, 2012.
Oli
Member #: 1910
Wilts
That looks bob on!
You said testing the market, how much would you say they would cost?
On 8th Feb, 2009 mini_surfari said:
That looks bob on!
At a guess, Id say around the £50 mark with the fixings.
Considering others of a similar design are around £100 its quite cheap.
Any interest then?
Paul
I'll have one of those in the near future. Just cant afford it at the moment after the dyno session and the shoot out this week end *oh well*
Its almost how I was going to make one. Good job!! :)
Give us a shout when/if your ready then mate.
Actually if theres enough interest Ill get some punched out and I may have them on the shelf
Paul
mini93
Member #: 2017
Warwick.
that looks top! really nice n well presented, shame wont be seen really :p
David.
looks nice what you have done Paul, do you find your camshaft last ok? was just worried about the cam not getting much needed oil on it.
Ive used the same cam now for 6 years, still no wear on it, and Im only just now replacing my pistons and rings after 6 years too.
If you think about it though, oil flings off the crank big ends after coming through the bearings, thats got to be enough
Paul
Edited by paul wiginton on 8th Feb, 2009.
Paul,
I'll take one as soon as they are ready.
On 8th Feb, 2009 Paul S said:
Paul,
Ill get the alu ordered ASAP then
Paul
I see what your saying Paul, Well 6years and NO wear, looks like there are no issues with that set up, Nice one. So what are the benifits you think? Is it done just to stop the drag from the crank on the spraying oil coming from the box?
Yes, it supposedly stops the spray of oil from the gears, that is thrown upwards, hitting the crank and slowing it down.
Ive seen wild claims that it releases around 3-5 hp but I dont believe that myself. I do believe that it helps the engine pick up sooner though, which is great for my n/a but would be good on a turbo too as it would possibly get over the lag sooner.
An example. My 310SC cam used to pick up at 4,000rpm, after fitting the baffle it picks up from 3,200 in 4th gear from 40mph
Paul
PaulH
Member #: 2340
Dublin Ireland
Ill take 2 Paul at that price :)
On 17th Feb, 2009 Rob H said:
Oli
Member #: 1910
Wilts
Im also interested in one of these, however not until i have finished the rest of the engine. So ill be in contact in the near future if thats ok.
OK, Ive started another thread in the For Sale section to take orders
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=271354
Paul
Radleigh
Member #: 1643
West London
i'll take one :)
philc
Member #: 1346
bromsgrove
interesting, good piece of kit
bollocks, i've just made one of these!
nowhere near as nice either.....
I'm sure i've said this before but i'll say it anyway....
the box sprays unfiltered oil onto the bores and cam etc, i much prefer the idea of stopping this and just letting the filtered oil from the crank get there.
If your paranoid about the bores and cam whack in som oil jets and use a drilled cam.
That is a very good point
Paul
nice, but ive seen better...
http://www.minifinity.com/distribution/vie...windage#p559508
haha, bless....
